VAF on Twitter:
@VansAirForceNet
  #11
Old 11-02-2022, 06:10 AM
bobnoffs bobnoffs is offline
i bought a 50 gallon tank mounted on a small trailer with a 12 volt pump and all the trimmings. originally i thought i would haul it to the gas station but what i am doing and it is the easiest for me is to bring 5 gallons whenever i go to the airport. the can sits firmly on the 50 gal. tank so it is easy and no mess or risk to use a jiggle hose and dump it into the 50 gal tank. when i fuel the plane i pump from the 50 gal tank. fuel is filtered and no risk of damaging skin of airplane.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
RV-12 airworthiness cert. 11/30/2021
first flight 7/25/2022
Old 11-02-2022, 08:11 AM
MacCool's Avatar
MacCool MacCool is offline
I don’t think that it’s rigidly enforced, but somewhere in the lease agreement at the airport where I rent my hangar is a clause which prohibits storing fuel in there. I don’t think that that is a rare prohibition at some hangars.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 11-02-2022, 08:41 AM
that's true. probably could be extended to 5 gal jugs too, depending on the management.
Bob Noffs
n. wi.
Old 11-02-2022, 11:28 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Originally Posted by seagull View Post
I fly out of Redlands Ca, hot in the summer. I use Costco 91 octane and check every jug for alcohol content. Typically it is 7 - 8% year round. On long flights I hit 10,000 - 11,000’ and have never had a vapor lock issue.
Vapor lock at altitude is a manageable problem... Vapor lock on takeoff can result in a very bad day. Pay attention to heat-soak on the ground. I had vapor lock in early spring (winter fuel) on a warm day. Repeated takeoff / landings with long downwind taxi. Engine decided it wanted to quit making power at about 400’ AGL. 912 ULS tried to shake itself loose from the airframe and almost succeeded. Gets your full attention really quick….
I shouldn’t speculate… but I would bet money that several RV-12 takeoff accidents can be attributed to vapor lock. Difficult for NTSB to prove… Fuel lines run on top side of hot engine – not a problem in cruise flight, but ground ops need extra care and planning.
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 11-02-2022, 11:57 AM
seagull seagull is offline
You are correct, anything out of the ordinary is more dangerous at low altitude.
I mentioned the high altitude no vapor lock because of what Bob Y said, “Higher RVP, lower octane and increased altitude are ingredients for vapor lock or fuel pump inlet cavitation”
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 11-02-2022, 07:53 PM
chop1 chop1 is offline
Lance see PM
Old 11-02-2022, 08:22 PM
MacCool's Avatar
They freaked out (a little) even over the 5 gallons of kerosene I was storing for the bullet heater I was using to warm my hangar enough to work on stuff in the winter. They freaked out even more about the actual bullet heater. Not a major freakout about the kerosene...just a "we are concerned..." sort of freakout.
Dual Pmags
IFR equipped
Old 11-02-2022, 10:16 PM
My friend stores 40 gallons of 100ll in his hanger. He keeps it in aluminum tanks in the wings of his Mooney, oh wait that’s safer😂.
-- Walt --
Old 11-02-2022, 10:48 PM
MacCool's Avatar
That’s different, I guess. Their rules…not my hangar
Dual Pmags
IFR equipped
Old 11-03-2022, 06:48 AM
Brett H Brett H is offline
Default Transferring fuel
[quote=Piper J3;1643909]Use high quality fuel containers and 15-gal FLO-FAST container and hand-pump. I have been using Costco 93E10 for a least 500 hrs. Costco is top tier fuel supplier.
Out of curiosity, why do you transfer the fuel from the 5 gallon containers to the 15 gallon container before transferring it to the fuel tank rather than transferring it from the 5 gallon containers to the fuel tank?
Thanks.
Brett H
Columbus, IN
