VAF on Twitter:
@VansAirForceNet
Old 11-01-2022, 05:52 AM
Jcurry Jcurry is offline
Default Tire tube valve stem nut
Hey Guy's,
I noticed that the nut on the new tube's valve stem was loose. The nut on the old tubes valve stem was also loose. Is the nut supposed supposed to be on the inside against the tube or on the outside tightened against wheel? Or, is the nut not used in this wheel application? The nut being loose on the new tube indicated to me that it might be removed for some reason.
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
Old 11-01-2022, 06:22 AM
Bob Y Bob Y is offline
They are not used on the 12. See KAI section 35.
Click image for larger version
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 11-01-2022, 07:11 AM
Default Thanks again Bob!
Bob,
I went to the Matco website and the maintenance manual. Missed it.
Thanks again. I owe you lunch/dinner should we cross paths one day.
Jack
Titusville, Fl
Old 11-03-2022, 08:46 PM
Stansuski's Avatar
Stansuski Stansuski is offline
Default Rv-12 non IS
Does anyone know if wheels are different on a Legacy RV-12 , the word “discard” is not used on Legacy KAI. I have spent much time frustrated by including them in tube/ wheel installation.
Stan
RV-12 #120828 first flown May 2021
Based At FD04
