VAF on Twitter:
@VansAirForceNet
  #11
Old 10-27-2022, 09:44 AM
jbDC9 jbDC9 is offline
Originally Posted by DeltaRomeo View Post
v/r,dr <G>
Ha! Nice. It had to be done!
John Bixby
RV-8 QB sn 82030 - 1st flight Nov 2006
O-360-A1D/CS prop/Pmags
1950 hrs
Houston, TX
Old 10-27-2022, 10:17 AM
DennisRhodes DennisRhodes is offline
your, you're ; dear, deer; bear,bare; whole,hole; there's a bunch of them, just add flare and flair to you're list !!!! But we all knew what the subject was about.
DRRhodes
2022 VAF Supporter
RV9 N908DR
Old 10-27-2022, 10:52 AM
bshawco bshawco is offline
D'oh! I didn't even THINK of "flair" vs. "flare" but I managed to use both in the original post. Guess I'm so freaked out by flaring that my proofreading has flared out.
-Brad Shaw.
Mancos, CO.
RV-12iS (Finished Wings)
VAF Donation Made June 2022
Old 10-27-2022, 09:57 PM
ian greenland ian greenland is offline
Default Flare
I was out bush one day fixing a cool room, the copper flare 1/2 in cracked and my flaring tool nowhere to be found😢. I cut the tube fitted the nut and heated the end with Map torch,rounding out a reasonable flare with a 10 inch star screwdriver. Whilst still hot tightened the nut, never leaked ever since! Aluminium tubing is soft, if you donít flare too wide and cause the pipe to crack the nut will close up any slight angle difference👍
Old 10-28-2022, 07:07 AM
All it takes is practice, with what ever flare tool you use. RFT37, RoloFlair, etc. All are slightly different. Advice----cut some sections of straight tube, square the ends with a file and through some trial and error, figure out how much the extend the tube past the flare bar to get the right amount of flare, once the sleeve is installed.
For most of you, you'll be using 3003O-.375-.035 tubeing for fuel. So I'd start with extending the tube about .060 from the flare bar. Flare it per the tool instructions, then slide the sleeve up and see how it all matches. Shouls be about 1/2 the width of the sleeve. If you get it small, just reflare it slightly larger. If its too big, sometimes you can reduce the OD with a belt sander. The trick is once you fine the sweet spot, make a measuring tool to use with the bar to get the tube to the right height prior to flaring. Something like a rivet height gauge is the idea.
Now if you flare a different OD/ID tube of different material ( Like 304 stainless, .375OD/.065 wall) obviously more testing and practice will be needed.
Its part of the 'education and recreation' section of the build process. The 'education' turns into frustration for quite a while, until you get comfortable, then it becomes 'recreation'--
Tom
Click image for larger version
Name:	Tube Flare details.jpg
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 10-28-2022, 08:55 AM
Thanks for the detailed suggestions and encouragement, Tom. I may go through my entire coil of factory fuel line practicing, but so be it.
-Brad Shaw.
Mancos, CO.
Old 10-28-2022, 04:12 PM
Brad---you might use some, but its really not that much. You are just flaring a couple of inches so its not alot. Once you fine the sweet spot on a particular size of tube, make a little guage and hang it on the flare tool so you'll always have it.
Tom
Ridgeland, SC
Old 10-29-2022, 05:50 AM
Tim Lewis Tim Lewis is offline
Originally Posted by TS Flightlines View Post
All it takes is practice, with what ever flare tool you use. RFT37, RoloFlair, etc....
Tom
Tom, what's the source document for that great flare attachment you posted? I'm keeping that picture with my RoloFlare.
Tim Lewis
CFI, A&P
RV-10 N31TD - 1650 hrs
RV-6A N47TD - 1100 hrs (sold)
Old 10-29-2022, 07:58 AM
'Aviation Technician Integrated Training Program EA-ITP-GB","General section textbook. I got it from a fomer Marine Helicopter mechanic after he retired.
The old manual is here----start on page 192 for rigid tubes--
Tom
Ridgeland, SC
Old 11-15-2022, 04:45 PM
Default Rolo-Flare
For what it's worth to any other flaring newbies, I finally bought the Rolo-Flare tool and found it much easier to achieve good-looking flares right away.
-Brad Shaw.
Mancos, CO.
