VAF on Twitter:
@VansAirForceNet
  #11
Old 09-15-2022, 01:11 PM
seagull seagull is offline
At 1200rpm an out of balance nose wheel will shake but not as bad as when it decelerates around 1/2 that RPM and hits the natural frequency of the nose gear strut. Do it yourself and you will be a believer in wheel balance.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 09-19-2022, 10:35 AM
rmac1376 rmac1376 is offline
it is your front wheel out of balance. mine did the same thing until i tried the early lift of nose on takeoff to minimize the wheel speed....no vibration! common problem.
Old 09-19-2022, 04:38 PM
Jcurry Jcurry is offline
Originally Posted by HansLab View Post
The shake is quite severe to be originated by the frontwheel
On several occasions, I thought my engine was going to shake right off my airplane. Getting the nosewheel up right away and doing the wheelie takeoffs solved the issue.
I confirmed this was causing the issue by intentionally holding my nose wheel on the ground longer than normal. It shook everytime I did this...
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
Old 09-22-2022, 10:22 AM
HansLab HansLab is offline
Default Chapeau!!
Still cannot believe the results, but: after having balanced the frontwheel the shaking was gone.
Entirely.
30 grams of lead made all the difference. And concerning the small diameter of the wheel that is quite a lot, but the results count.
How I love this forum.
Let's continue it for a few decades.
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
Donation 2021 paid
Old 09-22-2022, 12:35 PM
WJaviation WJaviation is offline
Entirely.
What device did you use to balance the wheel? Iíll be doing it this winter as well.
Old 09-22-2022, 01:35 PM
Default balancing
I just went to a motorcycle workshop, where they had the appropriate gear to balance the frontwheel (Automotive did not work for the rim was too small for the gear they use there). Just stick-on 5 grams lead pieces. OUtbound pressure keeps it tight, the man said when I figured they' d be gone with a flight or two...
We'll see.
Hans Labruyere
Donation 2021 paid
Old 11-14-2022, 02:42 PM
Tony_T's Avatar
Tony_T Tony_T is offline
It is quite possible to install the stick-on wheel weights inside the wheel halves. Turn the wheel on the motorcycle wheel balancer and mark the heavy spot. Once the tire is deflated, remove the hardware and separate one wheel half from the tire, tube, wheel assembly without disturbing the clocking of the tire and apply weights inside the wheel halves opposite the heavy spot. Reinstall hardware loosely and repeat as necessary to achieve excellent balance.
Clean the places inside the wheel where the weights will go first with a suitable solvent, rubbing alcohol works well.
We no longer have lead weights available here in the US, and the weights shown are a lighter metal so it took several of them to balance the tire assembly.
This is the nose wheel under discussion. On the mains the weights can go on the outside.
Click image for larger version
Tony
E-LSA RV-12 ULS
Last edited by Tony_T : 11-18-2022 at 10:25 AM. Reason: Replaced image with a better picture
Old 11-15-2022, 11:47 AM
https://photos.google.com/share/AF1Q...RnSnJOYVFqZUl3
weights glued to the outside of the frontwheel. Comments of the supplier: "centrifugal powers will press the weight more thourrow"
Hans Labruyere
Donation 2021 paid
