VAF on Twitter:
@VansAirForceNet
  #261
Old 07-10-2022, 09:25 AM
todehnal todehnal is offline
Default Painted Rivet Removal
I have a small set of leather punches for making holes in leather of various sizes. One of them fits perfectly over painted rivet heads. All it takes is a couple of spins on the rivet head by hand and it will come out clean..........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 11-07-2022, 11:40 AM
backcountry backcountry is offline
I totally failed installing the service bulletin.
The rivet heads face aft of the bulkheads on my Aircraft and I was unable to punch out the stems in order to drill the rivets. I tried the lowest rivet because that would be the most difficult one. After one hour of working on that rivet I hurt my back and it took two hours to get myself out of the tail. Got blood all over the baggage compartment.
Iím an A&P and ATP over 6,000 hours and dealing with airplanes along time.
Do not go back in the tailcone without someone knowing youíre there because I didnít think I was gonna be able to get out
Old 11-07-2022, 01:31 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
My rivets heads also faced backwards. Really not a problem... Don't worry about punching out stems - just drill off the rivet head. I used 90 degree drill motor. Then use plier / side cutter to extract rivet shank.
You think that was fun.... Wait for broken counterweight SB...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 11-09-2022, 03:56 PM
thomasyost's Avatar
thomasyost thomasyost is offline
Default Removing Pop Rivet Stems
While doing this S/B, I discovered that a Pneumatic Mini Palm Nailer works great for driving out the old stems. Hardest part is fining the right 'bit' to use for driving. I was using the stem from a new rivet that was ground flat.
RV-12 #285
Resumed work on finish kit after 8 year break.
Avionics received but waiting on a bunch of SB parts before ordering engine.
Keaau, HI
Old 11-25-2022, 05:29 PM
bbaggerman bbaggerman is offline
Default Subtle crack
I did SB-00053 on my 1400 hour RV-12 last weekend. I'd say it wasn't too bad but I wasn't the guy in the tail cone, my buddy was. He didn't complain so it couldn't have been too bad.
We found a nice big obvious crack at F-1208, stop drilled it, put on a doubler, and moved on. The rest looked OK. We buttoned it up, and put on the cover, and finished for the day.
Later that night I got to looking at photos. As I said the crack at F-1208 was obvious. What wasn't obvious was the crack at F-1210, all the way back near the tail. I didn't notice it until I zoomed in on the photo that night. Luckily we haven't put the fuel tank back in yet.
I guess the moral of the story is that some cracks are move obvious than others. Be sure to take a good close look when you do the inspection.
Bob
Click image for larger version
ID:	34257  Click image for larger version
Name:	F-1210 Fwd Crack.jpg
Bob Baggerman
Niceville, FL
N233VA
Old 11-26-2022, 07:26 AM
Jcurry Jcurry is offline
Hey Bob,
Thanks for the write-up and the pics.
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
