VAF on Twitter:
@VansAirForceNet
  #11
Old 07-29-2018, 07:21 PM
JimMac JimMac is offline
Steve, I meant MS24665-359
Jim McCarter
Madison, AL
RV-12 N864RV 90 hrs TT
______________________
Donation Made for 2021
Old 07-29-2018, 07:35 PM
sf3543 sf3543 is offline
Sorry, don?t know the part number of the cotter pins off hand.
I just have a storage bin full of them I have been pulling from for years.
However, that?s probably the correct one.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
Multiple RV builder currently flying
RV3B & Legend Cub
Old 07-29-2018, 07:42 PM
RFSchaller RFSchaller is offline
You can usually find one that will fit at Harbor Freight or Home Depot.
Old 07-30-2018, 11:51 AM
OK. I called MATCO this morning and they told me that the correct cotter pin for the RV12 main axle is: MSC.11X2COTTERPIN Z/P. Trouble is I would have to order 55 of these to meet MATCO?s minimum $10 order. Does anyone know of a different source for these?
Jim McCarter
Madison, AL
Old 07-30-2018, 12:21 PM
jask jask is offline
"The part number for the cotter pin on the axle nut is the MSC.11x2COTTERPIN. It is on our website at:
http://www.matcomfg.com/COTTERPINZP-idv-3813-35.html
It is steel and is clear zinc plated.
The same size steel pin (7/32) from other sources would work fine.
The wheel on the RV-12 is the MHMHE51B. The axle assembly is the WHLAXLE3A. They are on our website at:
http://www.matcomfg.com/MHE51BESERIE...v-2354-30.html
http://www.matcomfg.com/AXLEASSEMBLYA3A-idv-2537-1.html
Both links provide additional details.
Thank you,
George R Happ
MATCO mfg
801-335-0582 801-335-0581 (F)
www.matcomfg.com"
I found this information
Old 11-14-2022, 07:33 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
FYI - the standard hardware store cotter pin size is 3/32, not 7/32 as noted above.
Bobby Steinmetz
Van Buren TWP, MI
RV-12iS #121228
