VAF on Twitter:
@VansAirForceNet
Old 10-28-2022, 12:15 PM
hamblin10's Avatar
hamblin10 hamblin10 is offline
Default Nav Light sealant
Does anybody understand why Vans would not want you to apply sealant to the areas I circled in red? They seal the entire nav light standoff fairing but where rainwater might seep in. Thanks!
Eric Hamblin
Private Pilot/A&P/Aerospace Engineer
RV-12iS in progress. N993EZ
Build 121398
Empennage kit received 8/11/22
Wing kit in work 07/11/22
Fuselage kit ordered 03/07/22
Finish kit ordered 03/18/2022
Owasso Oklahoma
https://eaabuilderslog.org/?s=MYRV12
Old 10-28-2022, 02:48 PM
Fisherpd Fisherpd is offline
I believe that is the area that the flox was applied to - a sealant between the tip rib and the flox there would affect the fit. That said - I had an issue with the light bracket blocking one of the rivet holes - Vans sent me a picture of one of the SLSAs they were building and it had a bead of sealant on top of that joint and the middle 4 rivets omitted.
(My real guess is that they did not do the flox at all - just filled the gap with the sealant & left the 4 middle rivets along the top out.)
Since I had already done the flox I just smeared sealant along the top after I riveted the fairing on.
Old 10-28-2022, 06:10 PM
WJaviation WJaviation is offline
I think I used 3M 4200 at that spot. I ran out of proseal and wanted something quick to put on there.
