  #11
Old 09-16-2021, 08:21 AM
NinerBikes NinerBikes is offline
You can use the "paper clip" icon for attachments, when you post, to load your photograph .jpeg files so that they show up in your post.
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
Old 09-18-2021, 09:34 PM
printbr printbr is offline
I replaced the exhaust system in my Classic 12. It improved the oil overheating problem significantly. This was a hot summer and I never had a yellow indicator for oil temp. Last year before the change I always had a yellow indicator shortly after takeoff n warm weather.
And as a bonus I now have zero carbon monoxide indications. So the exhaust leaks in the old system are gone.
Bruce Rawlins
Richland, WA
LSRM-A
RV-12 Flying
Old 09-30-2021, 01:09 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Check... https://legacy.rotaxowner.com/si_tb_...sl-912-025.pdf
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 735
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 10-01-2021, 10:08 PM
RFSchaller RFSchaller is offline
I canít win! No insulation and the engine overheats. Insulate and it accelerates exhaust failure.
I had an exhaust line break off a Continental O-200A on my first home built. I ended up with some charred wood at the edge of my firewall. That plane was always an adventure.
