Old 09-26-2021, 05:50 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Default Spark Plug Wire Fell Off In Flight…
This is weird....
Three years ago, I was diagnosing a rough running engine and replaced all eight spark plug caps thinking, at the time, maybe the 5 ohm resistor in one or more of the caps was damaged. The rubber boot gets manhandled when pulled from the spark plug and my thinking was the internal resister could get damaged. I replaced the rubber caps with NGK 90 Degree Elbow (LB05F) 8051. This spark plug cap is rigid phenolic and my thinking was the internal resistor wouldn’t get damaged easily.
Engine has been happy for over 300 hours until today. Flew in a lot of turbulence this morning and engine began running rough. I shut off one ignition at a time in flight and it showed both ignitions working, but one very rough. Returned to home base and removed top cowling to find top left rear spark plug wire not attached to the spark plug.
I pushed the sparkplug cap back on with no ratcheting sound and cap pulled right off. There is a spring circlip type wire in the cap that engages with the exposed screw thread on the sparkplug. When pushing the cap on the circlip wire “ratchets” down the sparkplug threads and becomes engaged in the trough of the last thread to hold the cap in place. I thought this was a very well proven design.
So, what happened? The circlip wire apparently is harder than the threads on the sparkplug and vibration most have caused the wire to wear a flat against all the exposed threads allowing the cap to lose its grip and come off. See attached photo...
Now I’m researching the correct NGK rubber sparkplug cap for 912ULS. I think the rubber cap does two things – prevents water ingress, and also holds the cap tightly to the porcelain of the sparkplug to prevent movement.
It’s always something Gilda….
Name:	Screen Shot 2021-09-26 at 6.53.59 PM.png
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 735
Old 09-26-2021, 06:24 PM
Tony_T's Avatar
Tony_T Tony_T is offline
“I thought this was a well proven design”
Everything on the 912 ULS motor is a well proven design. When you change something, there are almost always unexpected consequences.
Tony
E-LSA RV-12 ULS
SkyView Touch
Old 09-27-2021, 09:50 AM
Piper J3's Avatar
So, I’m trying to find exact Sparkplug Cap for 912ULS. It appears that Rotax uses NGK brand but assigns an internal PN.
From what I see the cap is 120 degree angle rubber boot. What I don’t know is how it attaches to the sparkplug. Option is for plug with bare threads or for the screw-on terminal.
VDO5FMH - 120 Degree Long Elbow Type, 10mm and 12mm Adaptable Plug Thread Size, 5 ohm Resistance, For Terminal Stud, Rubber Sheathed, Compact Type
Or
VD05EMH - 120 Degree Long Elbow Type, 10mm and 12mm Adaptable Plug Thread Size, 5 ohm Resistance, For Terminal Nut or Integrated Terminal, Rubber Sheathed, Compact Type
Can someone take a quick look at their engine and tell me if
• 120 Degree Elbow is correct
• What type of connection to top of sparkplug
Thanks in advance…
Name:	Screen Shot 2021-09-27 at 11.49.44 AM.png
Old 09-27-2021, 10:29 AM
rvbuilder2002's Avatar
The factory standard spark plug and plug boot on the 912 has always been the versions that uses the threaded stud.
There is a pull off test prescribed in the inspection checklist for each hundred hour inspection that verifies a minimum pull off force for each plug boot. This thread demonstrates why following that is important. Once one starts getting a little bit loose and can be influenced by vibration it will cause wear rather quickly.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-27-2021, 01:16 PM
Steve Melton's Avatar
I'm happier every day with aviation plugs.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 09-27-2021, 02:50 PM
skydiverlv skydiverlv is offline
Why? I have near 650 hours on my Bosch FR5-DTC plugs without missing a beat.
Larry Vandegrift
ULPower 260is
Old 09-27-2021, 03:20 PM
gasman gasman is offline
You mean those old metric ones.........
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 09-27-2021, 05:16 PM
Harvey rv12 Harvey rv12 is offline
J3
I had the same experience you described. Engine running rough, pulled cowl, sure enough left front bottom plug wire hanging loose off spark plug. Upon close examination, it looks like the brass/bronze connector had worn from connecting & disconnecting numerous times. It became oval, out of round and would not stay on the plug. After replacing with same design NGK plug cap, I’m considering trying the alternative cap style that use the (thimble/nipple?) found on most automotive plugs.
But I think I will wait until the brain trust Has deliberated.
I must say it’s never easy getting plug wires off the plugs, that’s probably the reason rotax recommends that specific plug cap.
TVO
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 09-27-2021, 09:19 PM
I had one fall off. I discovered it on the ignition check during run up. I think it is easy to not get full engagement when you put the cap on which is why mine came off. Since then (about 200 hours ago) I am extra careful replacing them and have had no issues. I’ve got about 1150 hrs on the original boots in about 10 years. I replace all plugs at every annual (about 100 hours of service). They’re cheap, so why not?
