AIRSPEED LIMITATIONS: SPEED KIAS REMARKS
VNE Never Exceed Speed 209 mph Do not exceed this speed
in any operations.
VNO Maximum Structural Cruising Speed
180 mph Exceed this speed only in smooth air.
VA Maneuvering Speed 132 mph Do not make full control
movements above this speed. Full elevator
deflection will result in a 6g load at this speed.
VFE Maximum Flap Extended Speed
100 mph Do not exceed this speed with flaps down
Vy Best Rate of Climb 86 mph, Vx Best Angle of Climb 74 mph, Vs Stall Speed Clean 54 mph
NOTE: The column headings read in large Bold Type: KIAS (Knots Indicated Airspeed) The speeds listed are in small print mph (miles per hour) A quick glance may confuse someone new to that aircraft. I suggest the "K" be removed from column heading and the speeds listed be matching to the actual instruments (or glass) mounted in the specific aircrafts panel.
in any operations.
