Today I finally got to the last part of building the left wing; installing the flaps. The manual says I have two options; one is the drill a hole in the aileron bracket and sliding the piano rod in from that end. As much trouble I had in getting the aileron push tube connected I wasn't going to go through that again. (Big fat fingers) So I elected to go with the option of removing three eyelets in the center of the hinge and cutting the rod in two. Well after much gruntting and groaning, I got the outboard rod in. But now I can only get the other rod in about 2/3rd of the way. I tapered down the end of the rod as a pilot and used lubrication in an effort to get the sucker to go in but to no avail. Now the rod is stuck. I almost pulled the wing off the stand trying to get it out. I need advice. Anybody got any ideas?
Paul
N277PM
Stuck in Lafayette
RV7A
Paul
N277PM
Stuck in Lafayette
RV7A
