Go Back   VAF Forums > Model Specific > RV-6/6A
Old 04-03-2021, 08:21 PM
echostar7 echostar7 is offline
Default missing lower cowl hinge pin retainer bracket
on my -6 cowl, the lower cowl bottom hinge pins have retainer clips which are not welded on, holding the handle end of the hinge pin and they screw in to the lower cowl with flush screws and a self-locking nut. Well one of those retainer clips went missing somehow. Is there a vans PN for this, it just looks like a folded over piece of aluminum large enough to feed the hinge pin through and a hole drilled in it for the screw. I looked at DWG 63 and I don't see a retainer clip for the two lower pins.
Matt
RV-6
Old 04-03-2021, 09:45 PM
rvbuilder2002's Avatar
What you describe was not ever documented as standard build in the plans. Perhaps the builder cut a section out of a piece of hinge and used one loop of it to make the brackets you are describing?
Scott McDaniels
Hubbard, Oregon
Old 04-20-2021, 08:10 PM
yes it is a homemade part but I think it is necessary as it is now because the hinge pins are very loose and will slide out of the hinge without much effort, is that normal for the lower pins? an alternative I could see is just going up to a heavier gage wire that matches better with the hinges.
Matt
RV-6
Old 04-20-2021, 09:17 PM
Having some method of capturing cowl attachment hinge pins is a good idea.
The original RV-6 plans had a suggested method for the bottom pins depicted in the plans, but it was different than you are describing.
Scott McDaniels
Hubbard, Oregon
Old 04-24-2021, 08:09 PM
Inhot's Avatar
Inhot Inhot is offline
Default I'm in the same boat
The lower cowl horizontal pins on my 31 year old Rv6 have no method to secure the pins. What is the recommended method?
2021 Dues paid
