Saf-Air oil drain and Superior XPIO 360 Exhaust
newtech
Patron
We have a new Superior XPIO 360 with Cold Air Sump and Vetterman 2 into 1 exhaust. The standard Saf-Air oil drain interferes with the Vetterman exhaust (zero clearance). What have others done to mitigate the exhaust interfering with the drain valve? Does the Saf-Air two piece low profile oil drain work?
I have the Superior IO-360 with a Vetterman cross-over exhaust and was able to fit the Saf-Air fitting on one of the drains (I think there are 2 on the bottom and I went with the middle one). The trickier connection was the sniffle valve; I recently switched to the Airflow Performance Manifold Drain due to clearance issues and leaks.
