Help locate a thread
N360DF
Member
Folks,
I try find a thread from a engine build, my searches are no success.
The engine was pimped with enlarged airbox and intake pipes ++
The builder talked about very high performance etc.
Anyone seen and know which one I talk about ?
Best regards!
Do you remember what model plane or engine size? Sometimes narrowing down the search parameters using "Advanced Search " helps.
I am pretty sure the engine was 360, the intake pipes was pimped hugh.
So was the airbox. I got a feel this builder had done several builds.
I tried narrow down, but noop...
I find it easier to use Google search and specify the site to search.
example:
site: vansairforce.com intake airbox
If you put quotes around the search terms, it will look specifically for that string only.
site: vansairforce.com "enlarged airbox"
The above returns your post only.
Any idea how long ago this was??
8-10 years ago (as I recall) or slightly less, AC aero engines was posting some interesting intake systems. ACE engine or something like that. Kevin Eldridge was also posting about them IIRC. He was on here as "Relentless"----haven't seen anything from him in at least 5 years.
Bob Mills also showed his new intake a few years back, but that was on a 6 cyl.
Mike S, thanks! You did beat google.
You are spot on, this is what I looked for.
But a shame is all the pictures is gone. the big wekness of this forum.
Wounder about some is flying around ?And what happend.
I am most intrested in the sump design for look into similar.
FWIW for others intrested in the subject this link
http://www.ac-aero.com/rs-series/
Shows the assembly! Scroll down little and right hand.
Best regards
