Max size SD card for G3X Touch
cccjbr6
What is the max size SD card that the G3X Touch can handle? The manual recommends 2GB but I don't see a max size. 2 GB is hard to find these days.
SD Card Type
As shown in the section Steve shared, the type of SD card you use is important. SD cards are limited to much smaller capacities, than SDHC or SDXC, but if you are able to find one it will work. We do not support the SDXC type so they are not an option. Any SDHC card will work for you, up to their limit of 32 GB in size, these are readily available.
Let us know if you have any other questions.
Justin
