Old 05-17-2022, 10:57 PM
MikeinPhoenix MikeinPhoenix is offline
Default PH retrofit kits
+1 for model specific retrofit kits. I bought my 9 (it has the original flap motor) and would sure like a retrofit kit. Keep up the good work Pat!
Mike McCann
RV-9A
Pulsar 1
Scottsdale, AZ
Old 05-18-2022, 02:54 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Default PH Aviation Retro Kit
Here is our sneak preview of our "retro kit." Really all you will need for all of the single-digit RVs are the two brackets, an AN5-13 bolt, nut, and cotter key.
Click image for larger version
We'll be offering these kits shortly. Here we're showing an RV-6 flap channel that we recently removed from the airplane with the legacy flap motor installed. We'll be taking this apart to make a video that will show the steps for converting to the new flap actuator. Next to it is a new RV-9 flap channel that we're currently building. The new flap actuator is currently being installed in the channel. They are both very similar and hopefully it's obvious that it's a pretty simple conversion in either case.
We're really looking forward to developing these kits and hopefully they'll make it easier for folks to convert to the new flap actuators.
ID:	25966  Click image for larger version
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com (Photography)
Track Me
Old 05-19-2022, 10:15 PM
wirejock's Avatar
wirejock wirejock is offline
Default Retro kit
I have the new actuator. The retro kit would really be nice
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 05-19-2022, 10:47 PM
Default Retro kits
Pat, thanks for the update and pictures of the upcoming retrofit kits. Itís great to hear theyíll be available soon. It will solve issues for a lot of us!
All the best, Mike
Mike McCann
RV-9A
Pulsar 1
Scottsdale, AZ
Old 05-20-2022, 01:49 AM
TASEsq TASEsq is offline
Will you make a kit for the -14?
If so, I might hold off on ordering until you do.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 05-20-2022, 06:30 AM
06ktrv6 06ktrv6 is offline
Can you guys enlighten those of us who are unaware of past issues with the conventional flap actuators. Once, early on at around 100 hrs I had to clean the grease out of the motor brushes. Other than that, there has been no other issues with my two actuators than Iím flying.
Kelly Landrum
Halifax, Va.
RV6 N6RP rebuilding
RV6 N9XK bought and flying
Old 05-20-2022, 07:16 AM
Pat Hatch's Avatar
We'll take a look at that, but if you'll have a look at our RV-14 Installation Instructions for the RV Max, you'll note that you're just modifying a couple of existing parts. It's on the web page here if you'd like to download it.
Pat Hatch
RV-7 (Sold)
Track Me
Old 05-20-2022, 07:27 AM
Saville's Avatar
Saville Saville is offline
Anxious to see the video. If this provides a simpler way to transition from the stock flap actuator to yours then I'm on board.
Flying RV-8 N880BC
2022 Dues - happily paid.
Old 05-20-2022, 07:50 AM
Thanks for the prompt reply Pat - Iíll take a look.
___________
Trent Stewart
Old 05-20-2022, 02:22 PM
Dugaru's Avatar
Dugaru Dugaru is offline
Default I'd be very interested in an easy retrofit for the -9
Well...
I bought a used -9A with the "basic" setup (old Vans flap motor etc.) The builder put the flap switch on the stick, with the "helpful" feature that the switch stays on when flicked up. The apparent idea being that in a go-around, etc., you just flip the switch up and then attend to other tasks while the flaps continue to go up. Key aspect of this setup: there is no limit switch to shut off the motor once the flaps are fully retracted. From what I can tell, this setup is not entirely unusual.
The problem is that with this old basic setup, if you inadvertently leave the switch up, or (worse yet) hit it *accidentally* one cold night while wearing gloves, and continue on your merry way, you might unknowingly run the flap motor against the stops for, say, 45 minutes, and that will absolutely cook the flap motor. The odor is really quite sudden, alarming, and distinctive; fortunately not much smoke is generated.
Obviously I know nothing about this based on personal experience.
I also have no experience with what happens if, in addition to all this, it turns out that somebody decided to use the wrong fuse for the flaps many years previously. Hello darkness my old friend. Thank you, backup battery attached to the Garmin G5
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2022 Dues Paid
