Hangar-ette Dimensions
1bigdog
can anyone provide the length of an RV-9a fuselage from tail without the empennage,
1) to the firewall only
2) with the front of the nose gear
I'm going to build a shed/hangarette such that when I'm switching between wings and fuselage work I can move each to safe temporary storage from the garage.
Michael B.
1bigdog,
I was finally able to go out to the hangar today. The approximate dimension from the aft end of the tail cone to the firewall is 174 inches. From the aft end of the tail cone to the front of the nose wheel fairing is 208 inches.
Hope this helps
By the way, send me your email address by PM and I will send several pictures on handling the construction of an RV9A in a garage, mostly solo.
