Just got ahold of a great RV-10, very few hours, new everything, glass panel, etc.
Engine has about 250 hours on it. When at cruise and running LOP, our #6 cylinder consistently runs 380 degrees or so, a full 70 degrees more than the coolest (#5). Numbers 1 through 4 are generally within 20 degrees of #5.
Last oil change we swapped injectors from #5 to #6 hoping that would clear up the problem, but it had no effect.
So, is this something common in the IO-540? Is this something a set of GAMI's could fix? Or am I probably looking at a baffling issue?
Any thing anyone could do to point me in the right direction would be helpful.
