RV-4 or RV8
chris0177
Member
I'm currently looking at these two models and haven't had the ability to "check the fit". I've only seen the RV-8 from a distance but never the 4. I'm 6'2" and 230 #'s. If anyone in the area has a completed plane I would love to come check it out. Please let me know.
Rockville, MD
Flying RV-8 at Dogwood Airpark (VA42) in Fredericksburg if you want to drive/fly down. I think there is an RV-4 here as well, but will need to check.
Carl
I'm the exact same size and weight. Before ordering my -8 kit, I sat in Van's demonstrator and it was a perfect fit. I expected that, because Van's designed the RV-8 for guys our size. I haven't sat in an RV-4, but I can tell it would be a tighter fit.
Try an F1 or F4
Before you build or buy you really should try on an F1 Rocket or the F4 Raider.
yes the four is a tighter fit. you don't get in a RV-4, you put it on. that said, i'm 6'2 250 and fit just fine in mine.
bob burns
RV-4 N82RB
