Been Having Some Fun Flying With My GoPros
luv2flypilot
Here are a few photos I have recently taken with my GoPros flying some acro.
I'm curious as to what type of parachutes you guys have on? Are you using the stock seat backs? Do you have cushions on them or using the chute as a cushion?
They are National 425 seat back chutes. I remove seat back cushions when wearing them.
JGT,
The development is called Discovery Bay, and is about 20 miles west of Stockton, CA, & about 50 miles east of San Francisco.
I have never been brave enough to trust just the stick on mount....
I am running 5 cameras at one time linked to a single remote in the cockpit and have flown them 15-20 times. I originally purchased a mount that uses a screw home but it did not work too well and was metal and would have scratched my paint if I used it the way I purchased it. I put 3m double sides tape as a padding but it was not secure enough and was rotating a bit during flight. If you clean the surface properly, the stick on mounts will not come off unless you use a fishing line followed by a cleaner to remove them.
