Fuel and Brake Fitting Thread Sealant
DonFromTX
I wonder if someone has discovered a fuel fitting thread seal that is good with ethanol/gasoline fuel. Someone used the "TiteSeal" product from Aircraft Spruce, it apparently disolves from the ethanol. I have been using Permatex "Thread Sealant" and am worried that it too may not be OK with ethanol based fuels and brake fluid. I can find none that explicitly says that it will withstand ethanol or brake fluid.
