Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
09-29-2022, 09:15 PM
Stainless is soft, I only use when needed for cosmetic reasons
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
09-29-2022, 09:51 PM
Not All
No, SOME Stainless is soft. There are alloys that approach or exceed the strength of the carbon steel used for AN507 screws.
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
In Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2022,...Thanks DR+
09-29-2022, 10:23 PM
You have a PN handy?
09-29-2022, 10:34 PM
ASTM A286 is a fairly widely used spec, 105ksi from my very fallible memory. Most of the usual fastener suppliers have them.
Dan Newman
RV-8
empennage complete
wings complete
fuselage in progress
09-29-2022, 10:49 PM
do not recommend stainless
I thought I would be smart and use stainless screws firewall forward. That was a mistake.
Stainless screws have a nasty habit of seizing up. I am told it has to do with the way the screws are cut. Just out of A&P school, I got a job working on rocket stuff that used hydrazine fuel. We had stainless steel housing with cut threads and stainless steel screws. Every few months when we disassemble a part and we would get a screw seized in the housing.
On my firewall forward stuff, I had an Adel clamp screw seize. I had to cut the clamp. Then I remembered my past experience.
I do have a few stainless steel button heads in the cockpit that go into nutplates, These are for the tunnel covers where a allen head would rub against the passengers feet. Every where else they are now banned and get changed when I have to unscrew them.
YMMV
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
09-30-2022, 04:17 AM
I sharpen the blades and flatten the tip of the screw driver on my polishing wheel and it seems to help a lot in addition to using the right size screw driver bit.
09-30-2022, 08:46 AM
Stainless will stretch under too much torque And the threads deform with the stretch which is what makes it seize up. We have the same experience with Stainless bolts up to a quarter inch - it will seize from stretching and we have to cut them off. This is on non-aviation applications.
Low torque applications work OK but there’s a fine line when you hit too much torque.
Rob Kelly
RV-10 Under Construction
09-30-2022, 09:29 AM
A286 stainless at 160 ksi is a very good material - hard to find and not cheap.
Here's a good hardware reference that you can download. It's free and shows what the hardware looks like and enough information to order it. But for a full description of the individual hardware, download the specification and look for it. Often a letter in the spec number can make a huge difference. I like everyspec.com for specifications when it shows up on a search.
Here is the spec for NAS517 flush screws. These aren't A286 but they are 160 ksi and will stand up to some abuse.
Aircraft Spruce has these at reasonable prices.
Dave
09-30-2022, 09:30 AM
Been using stainless Torx now for ~20 years on access covers, fairings, tank skin/wing, wingtips/wing skin attachments, etc. The heads will strip, but only if you don't fully engage the bit. But nothing nearly as sensitive as the Phillips. Make sure the nutplate threads are loose and free. They will gall. If it's more than finger tight, run a tap though it once and all will be good.
Bryan
'00 RV-8, built & flying
'60 Bonanza, bought & flying
'25 RV-9, building
'46 Cub, bought & sold
09-30-2022, 09:35 AM
Hmmm...That pretty much negates the vibration resistant (locking) feature of the nutplate.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
