Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
08-22-2022, 08:54 AM
Vans comment on rudder balancing
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Phase 1 complete 10/29/22
KAJO
08-22-2022, 09:56 AM
Originally Posted by Snowflake
At the end of the day I don't think it's been shown that an RV-7/7A operated within the published design/performance envelope is at any risk.
No one disagrees.
Trouble is, despite good intentions, sometimes they get outside the envelope. The plain truth is everyone makes a mistake from time to time.
BTW, I met a fella at OSH with an RV-7 rudder installed on his beautiful new RV-8. He said he thought it would give him more control authority.
Dan Horton
RV-8 SS
Barrett IO-390
08-22-2022, 11:00 AM
Originally Posted by rv6ejguy
If there was a systemic fault here….
Arguably if flown within limits, there is nothing unsafe about the -9 rudder on the -7. But as Dan pointed out and we all know…we all make mistakes. In the last 15 yrs, every single catastrophic RV rudder flutter failure has been a -7 with the -9 rudder. Not the RV-3. Not the RV-4. Not the RV-6, not the RV-8.
Makes one think…hmmm.
RV-7 Flying since 2004
IO-360 1 LSE & WW200RV
1,200 hrs+
08-22-2022, 11:44 AM
This is distressing information. I hope that individual reads this thread and retrofits an RV-8 rudder to his RV-8.
Carl N.
RV-8
KAWO
08-22-2022, 11:46 AM
No one disagrees.
So if you "beef up" the design, however you do it, and enlarge the envelope, won't you still have the problem of people making mistakes and exceeding it?
How far do you go to ensure that no pilot ever violates a design constraint?
2022 Dues paid!
08-22-2022, 11:56 AM
This excerpt is from my post #16:
"The problem appears to be that there are small rudder strength margins and small fin/rudder flutter margins outside that envelope when (the RV-7/7A is) equipped with the -9/-7 rudder. Note that RV-8s are not coming apart in-flight with the same regularity and for the same reason that RV-7s are. And I don't think RV-8 pilots are any better or more careful than RV-7 pilots."
There have been approximately 8 RV-7/7A accidents involving the rudder, with 11 fatalities. None for the RV-8/8A that I know of. The simple retrofit of the -8 rudder to the -7 gains a significant amount of safety margin, with no appreciable change in spin recovery characteristics.
Post #16 has some other useful information.
Carl N.
RV-8
KAWO
08-22-2022, 12:03 PM
Accident Record
What I can find:
RV4 structural failures zero
RV6 structural failures-one that was called a RV6 but was not built to plans. Modified RV3 wings among other poor choices. Continental six cylinder engine.
There are 4's and 6's that have been intentionally operated in excess of Vne, primarily for racing.
Racing at Reno is very likely to mean moderate turbulence, sometimes severe.
Many would contend that operation in moderate or greater turbulence should be limited to Va, which at Reno means one should not even bother starting the race.
08-22-2022, 01:29 PM
Sharp guy, just didn't know. He said he would change it when he returned home.
Dan Horton
RV-8 SS
Barrett IO-390
08-22-2022, 01:42 PM
We don't have the luxury of full FDRs showing control inputs in any of these accidents so you can't say what might have initiated overload or flutter.
I know of 2 stock 7s (turbos) which have been over 210 KTAS in level flight.
Straight and level flight in smooth air is a lot different than flight with a bunch of rolling G thrown in and coarse control inputs as far as structure deflection goes.
I assume Van's has tested to 220 KTAS? How far do you design or test to? 240 kts? 250? That still doesn't guarantee the structure is safe at those speeds when flown by hamfisted pilots.
You can't expect to do stupid things in airplanes, even if by mistake and survive all of them.
08-22-2022, 01:53 PM
The key point here is to increase the margins and then DON'T enlarge the envelope. Enjoy the existing envelope with increased margins.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
