VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 07-07-2022, 09:15 AM
lr172 lr172 is offline
Originally Posted by stringbender View Post
I posted a week ago about having vertical (up and down) vibration on NLG tire, after inspection I found two flat spots. I removed the classic aero tire, put a replacement tire/tube from my hangar mate and flew it. It was worst...but the tire was 1/8'' out of round. I then order two new ones from Spruce, and the tire was true. I then talked to a EAA Mentor who installs a spacer inside the wheel, so to obtain a normal torque on the 3/8'' bolt. Not the 7-10 foot lbs. The "trick is" to make the spacer big enough that the bearings are free to move, roll freely. That is quite a task. I made several spacers and the grease drag on the bearing made it difficult to tell. Too big and the bearing would rotate on the outside spacer (not to be confused with the inside spacer that was manufactured). Too small and you don't get a torque up of the bolt.
The goal I had was to be able to rotate the tire with bearings greased "one full turn".
History; I purchased the aircraft 1 year ago, everything has been fine until a vertical vibration was felt. 80 flight hours and approx 100 landings. I did notice the original spacers had rotated which I think was from the original owners history, it leaves slight grooves in the Yoke.
Suggestions?
Comments?
Question; Does anyone have a internal spacer dimension?
Just buy the matco axle. It is under $100 and is adjustable to create the correct pre-load for ANY installation. It is the easiest fix for the issue you have.
Larry
Old 07-07-2022, 10:32 AM
jask jask is offline
Suggestions?
Comments?
I saw several examples of the bushings that had locked up and spun against the yoke. If those bushings lock up, it also means the bearings are locked up. A correctly sized spacer between the bushings would set the preload and do the same thing as the Matco axle.
I disagree that a locked nose wheel would "not fold the gear".
RV-7 builder Ramona, CA.
Free prop balancing for Van’s owners.
RV-6A N665CM
Old 07-07-2022, 11:08 AM
Default Matco axle
Larry
Do you have the Matco axle installed?
RV-6A N665CM
Old 07-07-2022, 11:13 AM
Default Axle
Another solution is to replace the 3/8 bolt with a larger hard bolt.
RV-6A N665CM
Old 07-07-2022, 11:44 AM
Default axle
If you look at the Matco axle, that is effectively what they are doing. The 6061 spacer just makes the axle thicker. Just drill out the yoke and spacers and use a cad plated 1/2 bolt. That's the cheapest solution.
RV-6A N665CM
Old 07-07-2022, 11:46 AM
Yes, on both my planes.
Old 07-07-2022, 11:48 AM
No. The matco axle provides a threaded mechanism to set bearing pre-load SEPARATE from the torque on the axle bolt. It is NOT just a bigger axle bolt with spacers. In fact, it doesn't use spacers and uses the original 3/8 bolt.
Larry
Old 07-07-2022, 11:53 AM
If you believe the the NLG would permanently bend before the rubber tire broke traction with the asphalt, why would you even consider flying in one. Folded NLG = flipped plane. Not a lot of friction offered by a tiny 4" tire. Do you also feel that the MLG will fold over if you accidentally lock up the main tires via the brakes? If you trully believe these things, I am shocked you would fly in one. Do you really think a respected Engineer would design a leg that would fold before the tire broke traction? Dropping the nose wheel in a gopher hole at 50 MPH is a whole different matter when it comes to folding the NLG; Totally different energy profile.
Old 07-07-2022, 12:28 PM
RicoB's Avatar
RicoB RicoB is offline
I got the antisplat mod recently and its great.
Rico Burgos
2018- RV9a at AZ82 and KWHP
1959- C-150 at KMOD (Sold)
https://www.imdb.com/name/nm3018529
2022 dues PAID
Old 07-07-2022, 01:01 PM
Default Nose wheel
I was watching an RV6A landing a few months ago. I was 300 or 400 feet away but when the nose wheel touched down, probably at about 30 kts, there was a rapid oscillation of the gear fore and aft of several inches maybe about 6 times. The force to bend the nose gear must be huge.
RV-6A N665CM
