Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
08-30-2022, 03:15 PM
RV-8 fuel starvation accident
08-30-2022, 03:48 PM
Still processing that one
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Phase 1 complete 10/29/22
KAJO
Reason: Insensitive comment removed
08-30-2022, 03:54 PM
The shop obviously did not test for full-power runup and match the fuel flow to what should be consumed - the difference there should have been way obvious during any attempt to calibrate the fuel flow.
Garden City, TX VAF 2023 dues paid
N16GN flying 1,250 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Repeat Offender - 10 empennage in process.
08-30-2022, 03:57 PM
Some thoughts:
1. The report mentions that the fuel tank root ribs were pulled out of the wing skins. It would be nice to know if the forward attach brackets had the proper slots as depicted on the plans, or simply match-drilled holes? (An example of when it would be good for NTSB examiners to recruit assistance from someone familiar with the aircraft type).
2. Really sad that the fuel supply used a restrictor fitting intended to supply gauges. No mention if that installation was performed by the avionics shop that installed the G3 or if that installation was performed by the owner.
3. The report mentions that the 5-pt harness was intact, yet there were impact marks on the panel. The panel is fairly close to the pilot on the RV-8. But not close enough to allow impact with the panel unless the belts are REALLY loose.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2022
08-30-2022, 04:06 PM
Wow. Simply wow. I recently made a change to my fuel system and have had it independently inspected by two sets of knowledgeable eyes in addition to my own. Still, my spidey senses are tingling full strength at the thought of having potentially introduced the same kind of issue as noted in this accident report. Before installing the cowls I'm going to look at the plumbing again, thanks to this timely post.
08-30-2022, 04:07 PM
Originally Posted by rv8ch
I guess we can all learn something from this accident.
Nothing in the report tells us who plumbed it...
https://data.ntsb.gov/Docket/Documen...to%201-Rel.pdf
I once caught an engine driven pump plumbed backwards during a TC visit, but the fellow was a first time builder, and it wouldn't have run anyway.
Dan Horton
RV-8 SS
Barrett IO-390
08-30-2022, 04:32 PM
Originally Posted by DanH
To my knowledge, there is only one shop on the field there that will do panel installs on experimentals. I know the field quite well.
That still doesn't tell us if it was that particular shop that plumbed it, versus the aircraft owner.
08-30-2022, 04:41 PM
Super Moderator
Wow. It's interesting to me that the line is capped off. You have to wonder if the fuel pressure gauge was not hooked up at all.
It helps to have a checklist after a panel installation and have another set of eyes look things over, especially when there are so many potential changes in the engine compartment.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
08-30-2022, 05:06 PM
Wouldn't a run up have discovered this on the ground?
08-30-2022, 05:16 PM
Probably only a high power run up….most run ups are what say 1700 rpm….then 1000 and a dead cut check….so I’d think no….it was starvation at high power caused by the fitted restriction….
2022 dues paid gratefully. great site for help and info.
Thread Tools |
Display Modes |
Hybrid Mode
