When is a Phillips, not a Phillips..... ?
Thanks for the eye opener of how a screw became a screw so we can screw them up.
Who knew a screw could be so screwed up with the wrong screw bit.
Thanks again Art
There is way too much info there! I was really interested until I got to the square - phillips and saw I was only half way done!!
It does make me more aware of making sure I have the correct tip or screw driver.
I recall helping a friend do some work on his RV (which he had recently bought), and he was having a booger of a time with some screws.
Because they were Pozidriv, not Phillips. Once I gave him the right driver bit, no more problems (but I recommended he replace them with Phillips, like all the other screws on the plane...WHY someone used Pozidrivs for this one particular assembly was a mystery).
The right tools for the right job make all the difference... :)
Step 10 in the article references JIS screws - Japanese Industry Standard.
There was a post on this site a year or so ago that JIS bits tended to fit AN507, 509, etc screws much better than Phillips #2, both in hand tools and power tools.
I bought a bunch of JIS tips on Amazon and my screw head strip rate decreased about 90%.
Last time I checked, a pair of genuine JIS heads is about $5.
Why the pozi drives..or torx, or tri-wings?
So as builders, we all have options and choices in hardware. After 42 years in the heavy jet business, I've seen as many fastener types. Some are great, some are horrible. Building my RV-4, I used all reduced head titanium phillips head screws...the next owner (if there ever is one) will get a goody bag of spares, otherwise, he will post on here what the &^%$ kind are these. In day job we used a lot of Tri-wing and Quad-wing (offset Phillips), as well as Hi-torque Coin slots, and weird one off type fasteners not well known to the free world. Certain individuals in the industry , have easy access to procure such unique fasteners, and some are more durable than a standard Phillips head..as long as you have the correct bits. The Airbus products carry a lot of the Quad-wing offset Phillips..just saying, maybe the builder was an Airbus guy.
Without getting into details...uh, no.
Poszidrivs
Big fan of these!
After learning the hard way with classic British metal I came to love that drive shape if the look is a cross. The grab just feels right.
It came via a UK forum and I was so nerdy that I read the lot !!!
I have bags of Hi Lok fittings if anyone wants them - they were being chucked out at a local repair shop - can't see good fasteners go to waste !
I hate anything that resembles Phillips fasteners. Why do we still torture ourselves with that terrible design when something like Torx is so prevelant elsewhere?
I use standard MS hardware because could not find torx in 230ksi, cad plated, 100 deg CS screws in #4 #6 and #8?
Have a source?
