Go Back   VAF Forums > Model Specific > RV-9/9A
  #11
Old 06-17-2021, 02:33 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Originally Posted by agent4573 View Post
Best practice is to install bolt heads forward, up, or out. If you deviate from best practice there should be a reason for it.
Right - Van's deviated from the best practice - which is why I asked the question.....
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 06-17-2021, 06:46 PM
plehrke's Avatar
plehrke plehrke is offline
Designers have discretion for which side the head is located for many reasons including clearance to get bolt installed, ability to get nut on, and room for a torque wrench on the nut and turn the wrench. In my day job, this locates bolt head side most of the time. Clearance to moving parts can also determine head location and happens frequently in tight locations like servo linkages. Also, if fastener is on outer moldline (it sees air flow) the manufactured head (bolt head if a bolt) almost exclusively goes to the external flow side. You donít see a lot of rivet tails on outer moldline.
A reason that it makes no difference the direction of head is in a structural joint, if the nut falls off, the bolt is no longer carrying much, if any, structural load without the clamp up of the nut torqued properly and may fail as soon as any load is applied. Plus it most likely is in a location that never gets looked at in a preflight.
Where it may matter is in joints that only is loaded in pure sheer like truss structure or control system tubes and cables. Then if nut falls off maybe the bolt will stay in place long enough to be found before something bad happens. Big maybe, but if none of the above is a factor, put the bolt head up.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
