Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 08-04-2021, 06:28 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
When I built mine, I had two slots for the dimpler, 1/3 in from either end. This made it easier to dimple the ends of big sheets.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 08-05-2021, 09:31 AM
avatty avatty is offline
Lots of good ideas here ... for the heavy DRDT-2 I made a 2x2 rolling stand with lockable casters of the same height as my 2 EAA workbenches. The same, but without casters, for the lighter C-frame riveter. A very flexible setup that gave good support to everything regardless of size or shape.
Tom
Walnut Creek, CA
RV-14 slow-build - finishing kit in progress
1949 Cessna 140A - IRAN'd 2017
Dues paid for 2021
Old 08-05-2021, 12:32 PM
SantosDumont SantosDumont is offline
I use an adjustable height rolling table from home depot to clamp the DRDT2 and then another workbench to lay the skin on.
Old 08-19-2021, 10:58 AM
PatMac PatMac is offline
"The use of a bit of tube over the rivet also helped keep the flanges flat onto the rib."
interested in this process. Would you have a pic or could you elaborate. Thanks in advance.
Old 08-19-2021, 11:31 AM
BOHICA BOHICA is offline
Originally Posted by wirejock View Post
Mine was like Ty above except...
I use EAA benches. Easy to move them around. The platform and C-frame were not permenant so everythjng could be arranged to fit the job.
I did the same thing as well. Works like a charm to optimize space.
Old 08-19-2021, 11:33 AM
Here is a link to the EAA plans. Only mod I did was to extend on two sides to allow for clamping to table but I can still butt end to end to work on longer pieces. I have my HS on the two benches right now with them butted together.
http://eaa1000.av.org/technicl/worktabl/tablefig.htm
Old 08-19-2021, 12:53 PM
Bgill Bgill is online now
Default Tube over rivet end
PatMac,
I couldn't find the original post you referenced, but I believe this is a similar technique to the tube referenced. I used small O rings over the rivet tail. The squeezer (or bucking bar) compresses the two flanges together before the rivet sets to aid in a tight fit. Nice to have when you have 10 rivets completed and one piece of metal that doesn't want to stay perfectly flat..
The image is just a set-up to show the washer and is not representative of actual surfaces to be riveted.
Click image for larger version
Byron
RV-14A 140466 N384RV - Flight Testing
RV-10 40253 N253RV Sold
Douglas, GA. 2020 Dues paid
Old 08-19-2021, 05:14 PM
John RV8 John RV8 is offline
Default Another technique
Originally Posted by Bgill View Post
PatMac,
For a similar task, I used a strip of very high density foam rubber (about 1/4 thick) attached to the bucking bar. The rivet would push through it and the foam would push the flanges together before the rivet began setting.
John Goodloe
RV-8. N6279G
Pay in November
Old 08-20-2021, 04:47 PM
Ender Ender is offline
PatMac,
I have never understood how this works. Doesn't the o-ring need to be thicker than the rivet tail is tall (so its squeezing the two pieces together)? I've tried making tubing thicker, but the bucking is always ugly. What am I missing?
Building RV-14A
Flight Test Engineer
www.hikebikefly.com
Old 08-20-2021, 04:59 PM
Agreed, the image I posted was just some components I had at the house. Everything else is at the hanger. The O ring should be roughly the same height as the rivet tail at the start. As it squeezes. Everything gets pushed together.
Try some samples and see how it works.
Byron
