Old 08-20-2021, 04:51 PM
Jake14 Jake14 is offline
Default brake return springs
Has anyone added brake return springs to the stock master cylinders of the 14? I've had a dragging brake occasionally and had trouble replacing brake fluid from the calipers up. When I put a bungee cord on the top of the pedals to pull them back, the fluid flowed much better.
This seems to be a fairly standard mod on other RV's. Just wondering which springs and retainers to use...
Also wondering which is the best hi-temp lube to use on the brake pad guides
Thanks for any suggestions
RV-14A flying 520 hrs
Old 08-20-2021, 07:05 PM
RV10Pilot RV10Pilot is offline
I used these parts for brake return springs on my RV-10.
https://vansairforce.net/community/s...0&postcount=24
Old 08-20-2021, 07:18 PM
scard's Avatar
scard scard is offline
Just beware of shaft wear issues. I started out with additional return springs for many hundreds of hours (or a thousand hrs?). I removed them long ago. I think the best improvement is a single bolt through both sides of the pedal.
Scott Card
CMW E-Lift
VAF Advertiser
Old 08-21-2021, 01:32 AM
gasman gasman is offline
A 1/2" nylon spacer on before the spring will eliminate this issue.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 08-21-2021, 05:05 AM
Nova RV Nova RV is offline
The spring mod works great on the -14.
Name:	Brake spring 2.jpg
ID:	14888  Click image for larger version
Name:	Brake spring 1.jpg
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 08-21-2021, 08:36 AM
Thanks all! just what I needed
Old 08-21-2021, 12:11 PM
Avengerboss Avengerboss is offline
Default Brake springs
We’ve been just replacing them with Grove Master cylinders. Cures all the Matco dragging issues
A&P, RV Prebuy inspections
Finished and flying our 10
Got me another RV8 to finish building
finished & flying 14A assist build SOLD
Building another 7 !!! Finished SOLD
another 14A assist build, Back at it again
Built: two 7s, two 8's, two 9As,10,12, assisted in 2 RV14As ,RANS S7
RV Jackpoints mfg'r "wintermotorsports.com"
When does a repeat offender stop????
Old 08-22-2021, 11:17 AM
calpilot calpilot is offline
If the alignment or shift of the alignment during brake application causes misalignment, the shaft will hang up or wear. If the alignment is proper, springs are not needed.
DAR Gary
