Fuel system rebuild
NewbRVator
Fuel system rebuild.
Hi I am going to rebuild my fuel system from the firewall forward. Currently have a carburated O-360 A1A.
Should I keep the carb?
Go to FI?
Lines and Filters?
Anyone use McFarlane?
Kind of a big project but I have a mid-time from new factory engine and should have many happy hours.
Thanks for any input.
Is there a specific reason for the rebuild? Reason for wanting FI instead of Carb?
These are important questions because the answer could include anything from a hose replacement to rebuilding your lower cowl.
FI is nice, but may be a much bigger project than you think. If you are just trying to replace old line I would send your current ones to TS Flightlines. You will have a new set in a couple of days. Replace the fuel pump, and you are done.
Yes it seems FI conversion is likely bigger than I want. I like the flightlines referral.
Great responses. Thanks.
Herold-----there are ALOT of RVs out there with carbureted fuel systems that are just fine. If it works, stay with it. Changing to injection is probably a bigger project ( time and expense) than you may think.
Tom
I converted my mid-time O360-A4M out of Piper Archer to AFP FI while building.
Pro: Able to run LOP in cruise.
Con: $4k-$5k in parts.
Tom of TSFlightlines just happened to be on the same field at 3J1. Excellent workmanship and now a great friend.
Also plan to replace my sump with the Superior fwd facing cold air sump to gain some HP.
Difference is he has a flying airplane. More time consuming to convert, han if building it with injection to begin with. Even easier if the engine was already FI equipped from another plane.
Tom
