Old 01-16-2022, 06:19 PM
Code10 Code10 is offline
Default Used parts
Did I receive used or returned parts in my kit? These are the E-904 and E-903. Notice the fluted edges and dimples on the other. As you see it is how I received them from Vans. The aluminum is different as well as it is more brushed and did not have the blue vinyl on it. One is final hole sized and the other is not. The date sticker is 9/23/21.
Do I need to be worried? Has anyone else received these like this? My thoughts are that these were returned at some point. I paid for new parts and should expect new parts. I may give Vans a call tomorrow if they are open.
Brian
N259ES (reserved)
Working on horizontal stabilizer.
Exempt but 2022 dues paid
Old 01-16-2022, 06:24 PM
ERushing's Avatar
ERushing ERushing is offline
Default Heat treated parts
Those are heat treated ribs. They’re not used. The entire stack of ribs looks like that. Build on!
Eric Rushing
RV-10
99% done, 90% to go.
Down to the last bits!!
Molalla, OR
Old 01-16-2022, 07:25 PM
XP Aviator XP Aviator is online now
I had wondered the same thing as mine were just like yours. Makes me think this is normal as I doubt they'd of had two identical returns.
2022 donation made
