Old 11-12-2020, 12:55 PM
Weefle Weefle is offline
Default RV-10 Brake upgrade
My apologies if this has been asked before but I am trying to decide which path to go down for the brake upgrades:
If you have gone with Berringer did you do their master cylinders as well or use the stock Vans? Same question but if you went with Matco brakes did you use the Vans master cylinders?
If you used the stock master cylinders did everything work ok...are you happy with the install, any grief with plumbing it together?
Nose Wheel ...did you go with Berringer or Matco?
Is it worth having tubeless tires that Berringer does?
Any feed back appreciated
Keith
____________________________________________
RV-10 in progress
CGMMD reserved
Dues paid till 2022
Old 11-12-2020, 02:35 PM
cderk's Avatar
cderk cderk is offline
I think its all about personal preference. I left everything stock except for the front axle. It all works fine
Old 11-12-2020, 04:13 PM
majuro15's Avatar
majuro15 majuro15 is offline
Don’t listen to Charlie. Go full Beringer. It’s the best.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2021 VAF Dues Paid!
Old 11-12-2020, 04:29 PM
Electrogunner Electrogunner is offline
Don't listen to Tim, he has more money then brains 😁
On another note, I'm happy with Matcos wheels and brakes with the stock master cylinders.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 11-12-2020, 06:02 PM
togaflyer togaflyer is offline
The stock brakes are fine but you can have brake fad if you lay on them hard. If you plan to just land at airports that have lots of asphalt stock brakes are not an issue. If you plan to land on something restricted, you will want to go with the after market brakes. Either brand is fine.
Old 11-12-2020, 07:13 PM
Rick RV-4 Rick RV-4 is offline
Default Follow on question
Is it easy to add the Beringers later after the aircraft is complete?
Old 11-12-2020, 07:27 PM
Rick, its not bad----BUT be advised that Beringer uses metric Banjo fittings, instead of standard hardware. They are made in France, so--
If you do decide at a later time to change things, you wont use the stock nylon hoses with banjo hose ends.
On the calipers, they mount different than the Matco or Grove, so you'll be doing a full upgrade.
Tom
Ridgeland, SC
Old 11-12-2020, 10:35 PM
After seeing the price difference between matco and Beringer......I think matco it will be. Somehow my brain is holding on to my money!
Thanks for the feedback!
RV-10 in progress
CGMMD reserved
Dues paid till 2022
Old 11-13-2020, 12:56 PM
rdrcrmatt rdrcrmatt is offline
Stock brakes are fine. I can get the plane stopped in 880ft.
Matt
CFI / RV-10
Old 11-13-2020, 02:32 PM
rocketman1988 rocketman1988 is offline
Default But
...but can you do it more than once?
Everything is just fine...until it isnt...
Bob
Aerospace Engineer '88
RV-10
Phase I COMPLETE!
Dues+ Paid 2020,...Thanks DR+
