Old 03-09-2021, 09:00 AM
MS1095 MS1095 is offline
Default Cowl Hinge Alternatives
Vans is out of the 1/8" Piano hinge. Has anyone used different hinge material around the firewall on the top cowl (RV4) I have some MS20001-6 on hand. The eyelets are smaller than the Vans hinge. The Vans hinge is .125 ID and uses a .090 pin around the curve. The MS200 hinge has .090 ID eyelets.
The MS2001-6 I have is 2in wide as opposed to 1 1/2". I could sheer it down to size if the 2in would be too wide.
Old 03-09-2021, 11:24 AM
lr172 lr172 is offline
I would not. Even the bigger stuff get broken eyelets at times. You can buy the stuff at Spruce.
Old 03-09-2021, 11:54 AM
Can't seem to find at spruce. Do you have a part # ?
Old 03-09-2021, 11:57 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
https://www.aircraftspruce.com/catal...pianohinge.php
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-09-2021, 12:02 PM
bjdecker's Avatar
bjdecker bjdecker is offline
How much do you need?
PM me and we can make arrangements.
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 03-09-2021, 03:23 PM
sjhurlbut sjhurlbut is offline
Default extruded
Get the extruded type - much better. MS20001.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - C-GVBX- building
Old 03-09-2021, 07:30 PM
FinnFlyer FinnFlyer is offline
The reason you need 1/8" hinge is that the 0.090 pin will not fit in 0.090 hinge due to the curvature.
Now, it's possible that you could use 0.090 hinge if you can find a thinner pin, but I suspect a thinner pin would bend (kink) too easily.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 03-09-2021, 08:06 PM
Originally Posted by pazmanyflyer View Post
Not the same stuff Vans sells for the cowl.
Old 03-11-2021, 05:06 AM
fixnflyguy fixnflyguy is offline
Default A couple additional things
Matt,
Are you building or replacing on a currently flying aircraft? That particular hinge requires some additional massaging rather than just bending and drilling it up. The eyelets (firewall side and cowling side)must all be angle chamfered to prevent binding when curved, and its easiest to do before you bend it. The ability to get the pins in/out will be directly proportional to the attention to detail on the eyelet preparation.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 03-11-2021, 06:01 AM
Originally Posted by fixnflyguy View Post
Matt,
Bill,
I am building new. I think I found the hinge at McMaster. I should know when it arrives today.
Can you describe in a bit more detail, or post pics of what you did on yours.
