Old 01-21-2021, 06:55 AM
rmartingt's Avatar
Default Today's wild idea... 3d-printed stick grip?
I've been trying to reach Infinity for a few days to place an order (their order form won't work right) to no avail. While running off another batch of dummy Skyview components so I can do some wiring, I had an idea... what about printing my own stick grips instead?
Obviously PLA is out as a material due to temperature concerns; PETG might work, as might ABS or nylon (though I have no experience with the latter two).
For sure, I think the biggest concern would be strength of the part for abuse cases (control jam loads), part of which could likely be mitigated by ensuring enough of the stick tube is contained in the grip.
On the plus side, I could get it configured exactly as I'd want and not be limited by number, type, or position of buttons--not that I want a bunch, but I do remember a Paul Dye Kitplanes article about the Shuttle stick grip and placement of the trim switch and it sort of stuck in my head.
Thoughts from the peanut gallery?
Old 01-21-2021, 07:10 AM
N40ES N40ES is offline
Default Do It
"If you build it they will come" I like the idea of COLORFUL Grips. and matching pairs for co-pilot side? But not too many switches & buttons!
RV10 Bought Not Built
Old 01-21-2021, 07:54 AM
fl-mike's Avatar
fl-mike fl-mike is offline
There is a guy (Paul Swearingen) doing printed throttle grips.
https://www.3dstickandrudder.com/
Mike W
Venice, FL
N164WM
Old 01-21-2021, 03:08 PM
Aluminum Aluminum is offline
This is me learning to Loft in Fusion360:
https://vansairforce.net/community/a...1&d=1611266279
PLA will melt in the sun under a closed canopy. Use ABS or ASA filaments. They can be smoothed with acetone vapor for a very professional-looking result. These weigh a small fraction of my injection-molded Tosten grips, yet they feel just as rigid.
For the next experiment I ordered a dual-head extruder to attempt a TPU skin on an ABS body, for a softer feel similar to the fancy rubberized grips. Stay tuned...
P.S. The tropical fruit printed real nice too.
Dan V
'91 Zodiac 2013-2020 retired
RV-14A wiring
Old 01-21-2021, 07:52 PM
Steve Melton's Avatar
that is really cool! did you make it to perfectly fit your hand?
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Saville's Avatar
Saville Saville is offline
That's a great site. I wonder if they would make a P-51D (they have the P-51A,B, and C version) throttle grip with a PTT.
Flying RV-8 N880BC
2021 Dues - happily paid.
Old 01-21-2021, 08:32 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
You 3D printed the pineapple?
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 650
Old 01-21-2021, 08:38 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
No, silly. The duck.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 01-21-2021, 10:34 PM
rocketbob's Avatar
A few years back I was bored in a hotel on a work trip and wanted to learn how to use OnShape.
Name:	Screen Shot 2021-01-22 at 12.31.32 AM.png
https://cad.onshape.com/documents/15...8ecc93d9f8b807
The stick hole is parametric. Prints nicely on a resin printer.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-21-2021, 11:03 PM
Nah, just fooling around to learn how the Loft function works--it's addictive for us quantitative types to keep turning the knobs. This print does feel really nice in my hand, but the reality is that we hardly ever grip the whole stick in flight, usually only for a few tense moments when landing taildraggers. That's why I left the long ledge on the bottom, to rest two fingers for steering with gentle pressure.
Fusion360 keeps everything in the "cloud". I'd be happy to share the design with the world but have no idea how to go about it. If someone can explain in a few sentences I'll try and put it up.
Dan V
RV-14A wiring
