Keep VAF
Going
05-19-2022, 05:50 PM
how did you guys wire pitot heat annunc. into the G3X?
I have the heated but non-regulated version of garmin's pitot heater and would like to have a CAS "pitot heat on" message.
The original plan was to run a wire off the downstream side of the switch, through a fuseable link and into a discreet input on the GAD27.
Some sort of wire protection is highly desirable if I go this route, because the other wire coming off that terminal is the wire to the heater that's running through a honking big 20 amp breaker.
Unfortunately, I don't think I can get bigger that a 22 wire into the D-sub pin in the GAD27 connector, which would require a ridiculously small 26awg wire to make a fuse link. I don't have any wire that small, and don't know that I could crimp it successfully even if I did.
I considered an inline fuse, but space is extremely limited behind the switch panel, with only about an inch back there, so I can't have anything very bulky.
Is the answer here to make the fuse link 24awg into a 20 awg wire that has some strands cut out to get it to fit in the pin? Or is there a better solution? What did you guys do?
05-19-2022, 10:06 PM
I am working on my planning and doing a wiring diagram and decided to use a relay to run the pitot heat - since my CB's will be above the tunnel under the panel, saved me running heavy wires up to the panel. This way i can use a switch which when on provides a ground to activate the relay. I can use a DPST and also ground a discrete wire which i will run to the GAD27 or GEA24.
Obviously this only shows if the switch is on, not if the probe has any power but better than nothing.
05-20-2022, 08:43 AM
As pointed out an indicator light or discrete is very binary. It's simply on or off, that is all it will tell you. It becomes necessary to think in terms of cause and effect.
A pitot probe is a high draw component. In todays digital and LED systems it could easily be the highest AMP draw device in the ships electrical system, setting aside the starter.
As you reach for the pitot heat switch observe alternator AMP load. When turned on there will be a significant rise in load verifying the heat coil is energized.
Breezy
First offense RV-8; N594WR; 80594 (time served)
ECI TITAN IOX 360 A1A9N, G3X
Repeat Offender: 83137 (Flying 10/16)
N837DW; Superior IO 360; G3X Touch.
Exceptional Aircraft Award, Sun N Fun 2017; Best Homebuilt, Mid-Eastern Regional Fly-in 2017.
One More Time: 140359, -14 in process, IO-390 (Maybe)
KHAO (Hogan Field)
05-20-2022, 08:56 AM
My setup is exactly like Trent, only my switch provides a 12v to the relay. I simply used one of active high discrete of my GAD27 to the power side of the pitot switch. When the switch is turned on, I get an indication on the G3X for the Pitot being on.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
05-20-2022, 09:52 AM
I connected a 1kOhm 1/4W resistor close to the high-power wire, then ran a 22 AWG wire to the GAD27 input.
Xavier Lebegue
Jouy-en-Josas, France
RV-10, finishing FF
2022 Dues Paid
05-20-2022, 10:31 AM
Regulated
I am using the garmin regulated pitot; it gets turned on during the after start checklist and off during the shutdown checklist. The G3X has built in logic for the heater and you can select from one of three modes. Works great.
I started with the unregulated and then switched. Glad I did.
Bob
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
05-21-2022, 08:28 AM
+1
In addition to dropping the current downstream of the resistor, it will also act as a fusible link. a 1/4 watt resistor cannot pass a lot of current before it's internals vaporize and open the circuit.
Larry
05-21-2022, 11:07 AM
Originally Posted by lr172
+1
Larry
But don't you have to solder them in? I'm not crazy about solder joints in something like this.
05-21-2022, 01:06 PM
To solder the resistor, I followed the recommendations given on Page 29 of https://www.verticalpower.com/media/...ual_rev-g1.pdf
If the AWG 22 wire to the GAD27 input is shorted to the ground, the current going through the resistor is approximately 14 V / 1,000 Ohm = 14 mA. The power dissipated by the resistor is then only 14 V * 14 mA = 196 mW, which is OK for a 1/4 W resistor. The GAD27 will think that pitot heat is off until the short is corrected.
Xavier Lebegue
RV-10, finishing FF
2022 Dues Paid
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
