Old 09-17-2013, 03:12 PM
tkatc's Avatar
tkatc tkatc is offline
Default Bracket-ology (No, its not March)
For those of us less experienced with servos and brackets...please explain how these install brackets work. I am thinking of buying the install kit for the servos so I can install now while the fuse is still pretty open. Problem is, I am reluctant to commit to any one manufacturer with the progress of experimental avionics changing at a blistering pace.
I THOUGHT I would fit Tru-trak servos until Garmin introduced a G3X package that is currently hard to beat, IMO. Is there a difference in mounting brackets between the two? Is there a difference between those brackets and any other manufacturer? ie Dynon, GRT, Trio, MGL.
If they are the same, I suppose it comes down to who offers the most complete install kit and at what price.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 09-17-2013, 03:48 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Garmin, TruTrak and (I am pretty sure) GRT are all interchangeable with regards to brackets (not wiring). I haven't used Dynon, Trio, or MGL servos, so I can't comment on those.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-17-2013, 07:33 PM
airmel's Avatar
airmel airmel is offline
Default Not quite...
The Garmin roll servo in the -7 wing has a different aft bracket than the TruTrak. The pitch servo can be mounted with a few extra washers.
This was my experience anyway. YMMV.
Melinda Harrill
Flying my RV-7!
Barrett Precision Engine - Superior IO-360 with AFP FI
Garmin Panel - All touchscreens
Old 09-17-2013, 08:22 PM
Captain_John's Avatar
What Mel said times two!
Tony, given that you have the same wing as I...
Anyways, I found this out because I have already installed the TT bracket and my Garmin servos won't fit it!
sooooo...
CJ
RV-7 Flying - 1,400 Hours
Old 09-17-2013, 08:31 PM
Ironflight's Avatar
Strange - our's bolted right in - but it was an under-seat bracket for roll.
Paul F. Dye
Old 09-17-2013, 10:45 PM
tkatc's Avatar
My -8 is the newer revision and looks like this.
I stole this pic from Matt Dralle. Is that mounting bracket a kit or did he make that? I don't want to cut the "wings" off my rib angles so I would want something like this set-up.
Also, I think I would be doing the under seat servo like this.
Same brackets?
Track my RV7A!!
Old 09-17-2013, 10:46 PM
Default Wait
These brackets - all manufacturers - are not hard to install late in the game. Just pull lots of wires now.
Old 09-18-2013, 04:47 AM
AH HA!
We are talking about the WING MOUNTED ROLL SERVO brackets!
Not the ones specific for the -8 that mount in the center section.
Sooooo mark that one up in the "been there, done that" category!
CJ
