Advancing Slick Mags Settings?
Geico266
As my mind wonders about timing an engine, I asked an A&P friend; "If 25 BTDC is optimal when running 100LL, why not time it at 28-30 BTDC when running mogas? Would this help get more power out of the engine if advancing the timing is a good thing with EI?"
This is on my 0-235 -3.
I guess I could always try it and report the results, but I thought I would ask the much more knowledgeable VAF crew first.
Larry, I recommend that you do not try this. To prevent detonation, lower octane fuel may require that timing be retarded - not advanced.
I have a Superior XP-360. The manual requires timing to be set at 25 deg BTDC for 100LL. It recommends 22 deg BTDC for 91 octane auto fuel.
Luis Luciani
