VAF on Twitter:
@VansAirForceNet
  #11
Old 11-28-2022, 09:52 AM
skylor's Avatar
skylor skylor is offline
Default 390 Sunp
The standard horizontal sump should be 2-5/16", like the RSA-5. The "cold air" manifold on the 390C and D is sized for an RSA-10.
That’s interesting about the 390 C/D sump. Unless Lycoming used a different casting than the IO-360A sump, it doesn’t look like there’s room inside the sump to increase the bore 1” or so in diameter:
Skylor
Old 11-28-2022, 10:24 AM
DanH's Avatar
DanH DanH is online now
Same as the 360A. Ask Ron Moring about enlarging the flange. Apparently it can be increased enough to eliminate the adapter normally used to mount an FM-200, bore size 3-1/16". May not be able to fit an RSA-10.
It helps that the FM-200 bolt pattern is rectangular, 3.12 X 2.82. The RSA-10 bolt pattern is 3.375 square. Sketch below is to scale.
Beyond that, I dunno. Have not done it myself...but I'd like to.
Name:	ScreenHunter_1433 Nov. 28 10.21.jpg
Dan Horton
RV-8 SS
Barrett IO-390
