Bob its been done "Star Wars"
Here are a couple of things to think about:
1 - I think it would be possible the build wheel fairings with a configuration that would allow a laterally moving panel to close the opening over the tire without having a lower bulge on the closed fairing.
2 - The fairings seem to expose much to large an amount of tire. I taxied out behind a Cirrus the other day and you could barely see the black of the nose tire. Mine shows about 1/3 of the tire with the corresponding large hole.
Bob Axsom
Bob you know many race guys use smaller fairings and (lamb) tires verses 5x5, basically the nose tire van sells but on the mains. Look at the racing Formula planes. Of course running smaller tires and lowering the faring closer to the ground has a negative affect on the ability to taxi, land & takeoff on uneven surfaces. Look at the middle pic below with the fairing dragging on the ground.
I agree perfectly sealing the fairing and wheel and reducing the protruding tire will reduce drag. I'd just go with smaller "pressure recovery" fairings, smaller tires, min tire protrusion and min gap around the tire, if going for speed. The active seals and doors sounds too complicated, but
the idea of clamshell doors on a fixed gear fairing has been patented! Patents 3750986 and 7108225 look interesting. Patent 3750986 shows a clamshell door on a fixed gear wheel fairing like a RV.
http://patft.uspto.gov/netacgi/nph-...&f=G&l=50&d=PALL&RefSrch=yes&Query=PN/3750986
http://patft.uspto.gov/netacgi/nph-...LL&s1=7108225.PN.&OS=PN/7108225&RS=PN/7108225
Hummm the "sharp ridge on the top of the fairing" is interesting. I gather is a longitudinal ridge especially towards the aft part of the fairing. The 3.5 length to width ratio is also interesting and fairly short. I have to say the door idea looks heavy and complicated. The author is Jim Bede him self. He never used it in a design so.........
Any holes to releive internal pressure will promote air flow through the fairings and I believe will increase drag.
Bob the idea of allowing a small amount of air to enter or exit the fairing in a "controlled" manner, is to keep the willy-nilly random air being sucked into the fairing. More importantly air shooting out around gaps between tire/fairing cause "interference drag", so a small exit in the trailing edge of the wheel fairing may prove useful as well. Think of it as trading drag for a little less drag.
Allowing a positive air flow into or air flow exit from the fairing, in theory can control air leaking around the tire.
Think of it as an AIR SEAL. Is it practical or will it give measurable drag reduction? probably not so the way to go is small tires, small fairing, min gaps and tire protrusion.
Boundary control - The "star wars" missile defense in the future may rely on high flying airplanes with optical sensors looking into to space. The sensors can not project through glass or plexi. They need an open window like at an observatory. On the top of the plane is a 'Cupola' (big hump fairing housing the sensors). The wrinkle is flying at +40,000 feet and 450 kts with an open 'window'. To get laminar air flow over the window, giving the sensor an unobstructed view of space and incoming ICBM's is a challenge. This is done by controlling pressure inside the cupola and the ramps around the opening. The idea of controlling flow using internal pressures has been done.
Showing doors (wide open in flight)
Showing inlets
