How much permanent rudder trim should I expect to add? I have a 3 horizontal x7" vertical wedge (bent metal) 1" raised from the rudder trailing edge and it's still not enough. (The ball was nearly completely out to the right.) The plane flies true if I hold a little right rudder pressure.
