Keep VAF
Going
05-25-2022, 04:28 PM
#40 drill
Drilled at low speed monitoring that the drill is centered. Slight wrist motion as the drill is at the intersection of the rivet head and body. They pop right off. Use flush cutting wire cutter to remove shop end.
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Flying Phase 1
KAJO
05-25-2022, 07:02 PM
Originally Posted by rvbuilder2002
My 2 cents....
Riveted airplane structures with damage are repaired all the time.
The key is in how (at what skill level) the repair is done.
Example-
The phrase "drill out rivets" should not be done literally when parts are intended to be reused. Section 5 of the manual gives details on removing rivets in a way that will not risk enlarging the holes with drill bit. Using that procedure would be the first step in a quality repair.
Seconded. I would add to that: - If you are "twisting" a rivet out, I have found it is sometimes necessary to relieve the tension / friction on the shank of the rivet by drilling a hole all the way through. A #51 drill has worked well both as a "1 rivet size down" drill bit for AD3 rivets, and as a "reasonably safe" drill size for drilling through. Reasonably safe in that as long as you stay centered on the rivet shank, you should not gouge the edge of the hole.
- If you are punching a rivet out, you want to back the hole with something that will support the sheet around it - like a bucking bar with a hole / depression drilled into it. Also "punch" is likely too strong a verb here. You want to tap on it just hard enough to remove it.
05-25-2022, 08:19 PM
Nothing stops you from spending an hour drilling out rivets to see how you do, then making the decision based on an inspection of the parts.
Scott Black
VAF dues 2021
Instagram @sblack2154
05-26-2022, 05:30 AM
I had to replace the spar in the HS of my Dad's 8. (Long story.) I drilled out rivets and reused most of the existing structure. In my case with the strategic use of a 2 or 3 cherry max rivets I was able to avoid disassembling it completely which saved a lot of time. Point here is to think a little bit about your specific repair as sometimes there are shortcuts.
As others mentioned, center punch every rivet before drilling. Spend the money on new high quality drill bits. Practice on scrap first. Try to just go deep enough to pop the heads. Protect the part as this makes way more chips than drilling out prepunched holes during assembly.
You will get VERY good good at drilling out rivets and be able to do it quickly and accurately....which is not a bad skill to have. I'm repairing a Baron currently and saved myself nearly $1000 by drilling a part out of a salvage plane this weekend. I never would have attempted this previously.
05-26-2022, 09:26 AM
Go slow and remove the skin(s). THEN evaluate any parts that might need to be replaced in the spars and ribs.
Chances are you may have a few misses and that's what oops rivets are for.
If you don't push too hard when drilling and don't drill all the way thru, you can use a similar diameter sized tool such as a old punch that has been ground down and with just a small wiggle, snap the head off the rivet.
Grind down a pair of wire cutters so one side is flat and you can grab the other side of the river and pull it right out.
Remember it's OK to make the skin hole bigger since you are replacing the skin. It the rib/spar underneath that you do not want to enlarge. Again, if you do, oops rivet it.
And the HS spars are quite a bit of work compared to a re-skin.
You-Tube has a video on removing rivets.
Webb Willmott
Jackson, MS
RV8 - Current Build
RV7A - N32WW
05-26-2022, 10:50 AM
Drilling rivets
I drilled my HS apart. No oops rivets.
You've received tons of excellent advise.
Here's my method...
-Use an auto punch to center punch every rivet you plan to drill. Make the punch mark nice and clean
-Use a bit 10 units smaller, #50-51. Start slow and walk back to center as needed early. Drill the center almost all the way through.
-Use a drill stop with #41 to drill only as deep as the rivet head
-Pop the heads off.
Some rivets will drop out so be ready with clekos. You don't want more stuff damaged. A modified auto punch ground down to dimension will knock out quite a few shanks.
Use a bucking bar and punch to remove remaining stubborn rivet shanks. I have bars made for the job with a hole to fit over the shop head. Second person is needed. Resist the urge to punch without a support. It will bend things.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
05-26-2022, 12:46 PM
Thanks guys!
I will certainly try the rivet removal and rebuild route, and if it just doesn’t go well, I’ll salvage what I can or rebuild with all new. This is my second build so I’ve replace quite a few rivets. This should make me even mo better at it!
Thread Tools |
Display Modes |
