Chemseal Vs. Proseal The Differences ?
laserman
Active Member
So can someone give me the quick differences between the two ?
Both sold by Aircraft Spruce.. Reviews and general data sheets read about the same?
Proseal lists manganese dioxide as a component .. Which I think is just a filler/thickener agent
Both seem to be appropriate for fuel tank work/sealing..
With a clear preference in the postings for ?Proseal? ?
Just wondering.
Al
They are both the same. Only difference is the manufacturer that packages it.
I typically look for the best price that is in date code using the Mil Spec number of the product.
Both are manganese-dioxide-cured polysulfide sealants, qualified to (mostly) all the same industry and OEM specifications. The MnO2 is the curing/crosslinking agent.
