Cfrisella
Hi Everyone. I want to let you all know about something new we have that was requested by a fellow member. It's a small NACA, about the size of Van's standard scoop, with a built in eyeball vent. The scoop is carbon fiber and the vent is a plastic version supplied by ACS. Aluminum eyeball vents are expensive, so I felt this option would be best. If you have your own idea for a vent, the naca alone can be purchased, which gives you a nice flat area to work with. If your interested please contact www.boneheadcomposites.com. 90.00 for the assembly and 50.00 for the naca scoop.
