w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-13-2023, 04:37 PM
B6*P B6*P is offline
Default FS: New Aerosport IO-375 and Hartzell Composite Prop
Sold my kit, so I no longer need the engine or prop, both are brand new still in the crate/box. Here's your chance to get them cheaper than what you can buy them for today, with NO LEAD TIME!
SOLD: Aerosport Power IO-375-M1S, Counterweighted Crank, Superior Cold Air Sump, Dual SDS EFI and Ignition, B&C Alternator, B&C Starter, Vacuum Pump Adapter, Prop Governor Adapter, 9.7:1 Compression. Inhibited for long term storage after run-in at Aerosport. Built 3/2022. Stored with desiccant plugs in the cylinders and an engine dehydrator (not included). $46,000 https://ibb.co/qD3bJXb
Hartzell 74" Composite 2 Blade Prop. with spinner. P/N: G2YR/N7605W-2X new, still in box. $18,500
Old 03-22-2023, 05:16 AM
Engine Sold, Prop Still Available
