Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
03-10-2023, 07:04 PM
2022 RV12 Factory Built Pics
I'd like to add to Bob's recent post of factory 12 engine pics with a bunch of ones I took. I've found it very helpful durning my build to have a reference of what it should look like.
https://photos.app.goo.gl/NMmsUs5LpTkepxRF7
03-10-2023, 11:43 PM
RV-12 pics
Wow, great collection, will be very helpful. Thanks for posting!
Doug
Seattle area
03-11-2023, 06:15 AM
Item on right axel
What is the blue item affixed to the right axel in one of your photos?
Ken
First time builder
RV-12iS, Garmin IFR
Tuscumbia, Alabama
03-11-2023, 10:12 AM
It came with wheels pants but the owner took them off since he is based at a grass field.
03-11-2023, 10:13 AM
Looks like the wheel pant mount.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Great photo documentation, thanks.
-- Walt --
03-11-2023, 11:41 AM
Did you iS guys notice the high- temp RTV around the heat-muff gaps? Another “enhancement” not identified in the KAIs but certainly prudent since they’re prime CO ingress points. The bead of RTV along the SCAT tubing was another one.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
#121047
03-11-2023, 11:53 AM
Originally Posted by Bob Y
Did you iS guys notice the high- temp RTV around the heat-muff gaps? Another “enhancement” not identified in the KAIs but certainly prudent since their prime CO ingress points.
Since the heat muff is always at a higher pressure inside than the cowl internal pressure, there is no risk of Co entering the cabin heat system, but sealing leaks can improve the heat performance slightly.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips, ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR, A&P, EAA Technical Councelor
03-11-2023, 12:02 PM
Thanks for that explanation, Scott. Since we’re told to seal all of the firewall penetrations, it seemed like those should be addressed too. I guess it’s just prudent practice to seal the firewall.
#121047
03-11-2023, 12:22 PM
In that instance, the pressure is higher on the engine side than it is on the cockpit side, so there is risk of gases passing into the cockpit area
Scott McDaniels
Hubbard, Oregon
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
