w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 02-21-2023, 10:48 AM
seagull seagull is offline
I had my gearbox rebuilt at 1020 hrs. The engine has used E10 auto gas for the majority of its life, maybe only 50 gallons total of 100LL. I do not let it run below 2000 RPM. There was no indicators to overhaul the gearbox, I just wanted to see what wear was happening and get ahead of it if something was wearing. Wayne Flemmington at F70 did the work and explained the process as I helped. The biggest concern is if the spline starts to wear you need to fix the cause or it can get expensive to replace. My dogs had normal wear, nothing of concern. Since we were already inside the Bellville washers were replaced and the plastic shims. There is a step collar that was also replaced, this is an updated part with slots for better oiling of the spline.
My gearbox ran fine and could have gone a lot longer before rebuilding. The updated step collar is good to have but the original must have been doing OK.
The OP concern about a rattle when pulling off the power is a clue the splines are wearing due to the Bellville washers loosing pressure probably caused by the plastic shim washers deteriorating.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 02-21-2023, 11:09 AM
rcarsey's Avatar
rcarsey rcarsey is offline
Originally Posted by RFSchaller View Post
I do the breakaway torque check at annual that basically checks the spring pack force. It has always been in spec since first flight in 2012.
I should probably add that check to my annual (which I'm doing right now). I can report that there is still virtually no debris in the filter or on the magnets. The only abnormal thing is that I found a few red cloth fibers in the filter which is due to regularly wiping the dipstick with a red shop rag. I don't think that is enough to cause any real problems (but I will stop using shop rags!)
I also learned, just as a FYI for everyone, that gearbox S/N 74000+ has an additional oil spray nozzle. The factory/distributor upgraded my gearbox before shipping (Jan 14, 2019).. So most, if not all -12iS's should have this mod already in place.
Rob Carsey, Winfield Park, NJ
RV-12iS (N713) / Completed 12/2020 / 350hrs and counting
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
APRS Track or ADSBExchange Track
Old 02-21-2023, 08:39 PM
RFSchaller RFSchaller is offline
Good info, Rob. Thanks.
When I was at the ROTAX course the instructor recommended running the engine at 2500 RPM and then shutting off the A and B ignitions in sequence to stop the engine. He claimed it resulted in less vibration and stress to the gearbox during shutdown. Iíve always followed that advice even though it conflicts with the ROTAX Operator Manual.
Old 02-22-2023, 08:24 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
All rolling elements Ė gears, ball bearings, etc., can absorb shock and abuse much better when at speed (dynamic Vs. static). This is why car wheel bearings can withstand pot holesÖ. The Rotax gearbox has a hunting gear ratio for the purpose of spread wear evenly. All that saidÖ. best practice is to keep ground ops at a reasonably high RPM. I start the engine and warm up at 2600 RPM. Cold engine runs much smoother at this speed and prevents gearbox chatter because higher prop loading sets gear lash only in one direction. Chatter is a huge no-no for gears, splines, drive cogs, and overload clutch...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 02-27-2023, 12:23 AM
PEB PEB is offline
I changed my prop to an E-props and it runs much smoother with no vibrations and a higher cruise speed.
It only weighs 2 kg (4.5 lb) all inclusive and low weight should be better for the gearbox.
https://aircraft.e-props.fr/product_...oducts_id=2452
It is my aircraft in the picture on the e-props site. :-)
PEB
RV-12iS
Experimental
Denmark
Old 03-02-2023, 06:38 PM
Cyclone Cyclone is offline
Default Rotax Shutdown
I read with interest your 2500 rpm shutdown procedure. I always cringe when the second ignition goes to off with the low rpm shutdown. The result ranges from benign to a simulated prop strike.
I used the 2500 rpm shutdown the last two flights and will never go back to minimum rpm shutdown. It seems the additional inertia allows the engine to come to a stop without the bone jarring Kerr-Whump. Thanks for sharing.
RV12. Flying Aug 2019
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
Old 03-02-2023, 07:03 PM
Bob Y Bob Y is offline
Guys, the current revision of the POH says to reduce power to 2000 rpm before shutting down. Itís the process I follow and it seems to work just fine. Earlier versions said to reduce to idle for shutting down, but itís now 2000 rpm.
Click image for larger version
Bob Y - builder 12iS
N569TT first flight 2/9/2020
#121047
Old 03-02-2023, 10:22 PM
Looks like the info on 2500 RPM I got in 2012 was good. Too bad it took the thunder gods so long to figure it out.
Old 03-19-2023, 07:29 PM
rcarsey's Avatar
Well, to follow up and close out this thread.. I sent (actually, the paint shop I'm using in Tennessee sent) out my gearbox to Lockwood for servicing.
Lockwood's phone support was excellent (9-10a; 2-3p) and they indicated my symptoms were very likely worn dogs. They received, repaired, and sent it back out a day after they got their hands on it. After inspection, they confirmed that it was worn dogs, but couldn't say why it had happened at only 380hrs (they had copies of my engine logbook, and didnt see anything alarming as far as maintenance or 50hr oil changes [100LL]). The problem would just get worse over time, but at no time was it in danger of failing (no power/emerg landing). Additionally, my gearbox had the optional oiler nozzle in it which was supposed to help prevent/delay this problem.
The only thing I could possibly do a better job at is to plan descents farther out, chop-n-drop less, and land with power more often.
As far as removal of the gearbox, Lockwood indicated that careful tapping the back of the prop flange with a soft mallet usually does the trick..but just be sure it doesn't get cocked while coming off, as there are dowl pins which will cause it to bind up. No absolute need for the special Rotax slide hammer for gearbox removal.
Lastly, warranty expired at 200 Hrs, but said they may cover some portion of the parts (not labor) under their goodwill program since this is problem not normally seen until much later in life.. but its at their discretion.. fingers crossed.
The costs were roughly $350 labor, $2100 in parts -- the bulk of which is a new gearset (886-548) at $1300 and dog hub (958-929) at $370. They also did the 600Hr inspection, since it was close enough to 600.
ID:	39857  Click image for larger version
ID:	39859  Click image for larger version
ID:	39860  Click image for larger version
ID:	39861  Click image for larger version
Old 03-20-2023, 04:35 AM
Jcurry Jcurry is offline
Default Thanks
Thanks for the info Rob.
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
My youtube channel: Southern Latitudes Sport Aviation
https://youtube.com/@SouthernLatitudesAviation
