w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-08-2023, 10:45 AM
Jcurry Jcurry is offline
Default Replacement Brake Lines?
Hello,
I have a legacy -12 with the aluminum brake lines and they are corroding. I thought I saw on here that there is someone who makes brake hoses. Am I correct? Contact info?
Thank you
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
My youtube channel: Southern Latitudes Sport Aviation
https://youtube.com/@SouthernLatitudesAviation
Old 03-08-2023, 10:48 AM
DHeal DHeal is offline
Try this company:
https://www.aircraftspecialty.com/rv-12.html
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,260+ hours (as of Feb 2023)!
VAF donation through June 2023.
Old 03-08-2023, 11:24 AM
HansLab HansLab is offline
Default corrode
What do you mean, they are corroding: outside, or inside? What's the age of your plane, please?
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
Old 03-08-2023, 11:43 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by DHeal View Post
Yep.......
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-08-2023, 12:09 PM
seagull seagull is offline
I changed to Aircraftspecialty lines on mine because the aluminum ones would cause the caliper to drag and squeak if they weren’t bent just right. The flexible lines solved that.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 03-08-2023, 03:59 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
I changed to Aircraft Specialties braided teflon brake lines because I fly off grass runway. Tall weeds at TO and landing speeds will damage soft aluminum brake lines....
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
Old 03-08-2023, 06:43 PM
Hans,
I have a 2011. I live in Florida. The outside of the lines are corroding.
Jack
Titusville, Fl
Old 03-09-2023, 06:02 AM
Hi Jack, Steve and I have tried to make this process easier by ordering directly off our website store, https://aircraftspecialty.com/rv-12.html. Just choose RV12 gear legs, add to cart, and check out.
Tom and Steve
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 03-10-2023, 04:36 AM
Tom and Steve
Thanks for the info. My CI is next month and I will probably do it then.
Jack
Jack
Titusville, Fl
