Old 07-14-2015, 07:11 PM
jtrollin jtrollin is offline
Default Wheel Fairings... so what am I missing
I do not understand how the wheel fairings mount to the belly of the plane, there is no way I can put nut plates there as the floor is already installed. The plans dont really say very well what to do that I can see. So what is the secret here?
thanks,
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Old 07-14-2015, 07:19 PM
RV9A Bill RV9A Bill is offline
Default Fairings on belly
One solution is to put nutplates on the exterior skin. Use stainless pop rivets to anchor the nutplates.
Old 07-14-2015, 07:56 PM
N941WR's Avatar
N941WR N941WR is offline
Keyed Rivnuts will also work.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-14-2015, 08:41 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
+1 Yes they do. Rivnuts are a good solution when you have limited access to install acual nutplates. A drop of JB Weld can help the Rivnuts from loosening and spinning too... even keyed Rivnuts. Just be careful not to get any JB Weld inside the threads but a tap can always be used to clear the threads.
Neal Howard
Airplaneless once again...
Old 07-14-2015, 10:45 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
We used small self tappers. Drill a pilot hole and then screw them in. They have never come loose and unlike the wheel pant screws in nut plates that get scattered all over the countryside, they stay put.
YMMV
David Brown
Old 07-15-2015, 05:27 AM
Auburntsts's Avatar
The plans call for three #6X1/2" SS sheet metal screws plus a AN509-8R8 that corresponds to an existing hole for the bottom wing root faring that gets overlapped by the upper intersection faring. See figure 1 on page 48-12.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 07-15-2015, 06:19 AM
rleffler's Avatar
rleffler rleffler is offline
If my memory serves me correct, I have a couple nutplates and the rest are sheet metal screw like the plan specified. I'll see how the sheet metal screws work before I install rivnuts. Mine have been in for almost two years without an issue.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-16-2015, 12:24 AM
RV10inOz's Avatar
Thats them??they work fine!
David Brown
Old 07-17-2015, 09:58 PM
Wayne Gillispie Wayne Gillispie is offline
Yes, sheet metal screws work fine per plans.
Good judgment comes from experience, and a lot of that comes from bad judgment.
