  #11
Old 05-06-2015, 08:35 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Taxi with the slider canopy open is fine. Flying with it open is a recipe for disaster. Proper airflow over the tailfeathers in flight is kinda important in the RVs.
Neal Howard
Airplaneless once again...
Old 05-07-2015, 10:46 AM
66mustangfan 66mustangfan is offline
Default Open Canopy
Someone here mentioned the Thorp 211 can fly with the canopy open. This is correct. I found one of these planes for cheap so I bought it as a restoration project sometime ago. I hope I'm not high-jacking, but does anyone know anyone with this plane so I can get more info/build plans. preferably in the Southern California area or Utah. I know most of you are RV guys, but I also know the aviator scene is close-knit. Just thought I would throw it out there. This project needs to tie me over until I can afford an RV!!!
Mike
Old 07-09-2015, 04:02 AM
Ghost two-six's Avatar
Ghost two-six Ghost two-six is offline
Interesting you should mention the Thorp Mike. I was noticing the other day that a fellow could pick up a decent flying Thorp T-18 for LESS than the cost of a quick build Kit and have an aircraft that would come pretty close to RV performance for way less money.
Save Money - Outsource Congress !!!
Old 07-09-2015, 06:31 AM
edsong's Avatar
edsong edsong is offline
Default Too fast
Open cockpits are fine for 100-110 mph airplanes or slower.
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 07-09-2015, 06:59 AM
maniago's Avatar
maniago maniago is offline
As you would expect, any canopy with sloping sides or back of any consequence is going to act as a drag, if not an outright parachute. Most already have detached airflow over the top, so slide it back and youre gonna get more of the same, but even more aft. Probably not what you want. Note the WWII fighters and such that had sliding canopies - straight sides and top. Ever seen a P-51 with the bubble canopy open in flight.....?
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 07-09-2015, 11:30 AM
az_gila's Avatar
az_gila az_gila is offline
Default Open bubbles
This bubble canopy was opened in flight -
And even the late model, full bubble Spitfires...
I think it depended more on other factors than "straight sides and top"...
Might as well add this one too...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-09-2015, 11:49 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Only as a (simulated) emergency measure. I've slowed waaaay down in flight to let a captive fly escape into the atmosphere on his own. Slowing to ~60 KIAS, I unlatched the slider, slid it back an inch or so, and the pressure differential pulled the fly out. I then re-latched the canopy - it was noticeably harder to slide forward but still do-able.
This was done with some thought, BTW - I had a parachute, was in the phase one test area, and was really designed to see what would happen should I ever forget to latch the canopy. It behaved just as others here said it would.
I wonder if the fly experienced shock cooling on his way down from 7500' MSL / 6500' AGL...
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
