Old 06-29-2015, 05:17 PM
Kaffer62 Kaffer62 is offline
Default where to buy small pieces of Aluminum
I haven't built up any extra pieces of Aluminum yet, but I need to fabricate a doubler. Where does everyone go when they need to buy such things? What type of Aluminum would I need to buy?
Frank Rivera
Peoria, Az
Rv-7 Tip Up/Tail dragger-Building
http://mykitlog.com/kaffer62
Old 06-29-2015, 05:23 PM
blueflyer's Avatar
blueflyer blueflyer is online now
Thumbs up Airparts Inc.
I use these folks: https://www.airpartsinc.com/
I just buy a roll or some angle as needed.
Old 06-29-2015, 05:25 PM
aeroaddict's Avatar
aeroaddict aeroaddict is offline
I have used Aircraftspruce for aluminum sheet stock before. You can buy smaller sizes which was an advantage for me. I didn't really shop around so you might be able to do better price wise.
In regards to the alloy type to use, a safe bet would be to use the alloy and temper of the base material. But I do not know your application and the specific application could affect the selection of alloy and temper.
Dan
RV-7 Slow Build - Sold
KEUL
Old 06-29-2015, 05:30 PM
Bo1000 Bo1000 is offline
Default Online Metals
http://www.onlinemetals.com/
Old 06-29-2015, 05:36 PM
If you want to just stock up on small sizes of various extrusions, blocks, etc, it's worth looking at ebay. The big vendors often sell off their 6061 'cutoffs' at pretty good prices. I haven't looked for 2024 sheet, but wouldn't doubt you could find that, as well.
Charlie
Old 06-29-2015, 05:43 PM
BillL BillL is offline
I found that Vans usually has the best prices, and shipping. A little slow on the departure, but reliable. I check "The List" for pieces close to what I need. If they don't have it there, they will cut it for you. Again, a little time.
I have had good luck with Van's, Aircraft Spruce and Wicks. I got tired of the large shipping for getting things as needed, so I ordered an assortment, .025. 032, .040, and some 063. Getting all in 2'X2' saved on the shipping costs.
Keep in mind minimum bend radii, or risk cracks, on 2024 t3. 063 is the worst!
Your geography could yield better sources.
Bill
RV-7
Lord Kelvin:
Old 06-29-2015, 06:16 PM
noelf noelf is offline
This is FYI for all that read this post. I work part time at an avionics shop that is also an FAA authorized repair station. We fabricate and install a lot of customized solutions for various agencies and businesses. As we fabricate the different solutions, we end up with several hundred pounds (yearly) of what we call "drops" (scrap aluminum) of various thicknesses and alloys including angle stock.
The owners of the company throw this stuff out about twice a year. They allow me to donate the stuff to our local EAA chapter for the members to use however they see fit.
As a suggestion, you may want to enquire if there are any like company's near your location and just ask if they have a scrap bin that needs to be "emptied".
Noel
RV-6A N6NF
tip-up
flying
Old 06-29-2015, 07:20 PM
xblueh2o xblueh2o is offline
I did the same through Spruce. I wished I had ordered a piece of something thicker than .063 at the time though. One day when I am doing a large Spruce order I will add it.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 06-29-2015, 08:51 PM
Thank you guys, you gave me a couple of options to look into.
Frank Rivera
Peoria, Az
Old 06-29-2015, 10:30 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
I go to Industrial Metal Supply (5051 S 48th St. PHX) for 6061 angle, bar, rod, sheet. They sell by the lb. they also have a remnants area of all types of odd balls left over cuts at 1/2 the price. 2024 is not stocked. Better selections (and less $$) from the online places Vans, ACS, Wicks, etc.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
